Accord injectors not firing. Please help. - Honda-Tech
Old 02-10-2012, 09:11 PM   #1
Default Accord injectors not firing. Please help.
A little history, 97 accord ex 175000 miles. Timing belt broke and bent the valves in cylinder 4. Got new valves put in head, reinstalled head, new timing and balance shaft belts and now the injectors will not fire. I have 145-150 compression across all cylinders, good spark to all plugs, have triple checked timing and valve adjustments. Question is, is there a sneaky ground wire I could have missed when I hooked everything up? I have spent all day looking to no avail. Any help appreciated.
sgettings775 is offline   Reply With Quote
Old 02-10-2012, 09:45 PM   #2
dglassmyer's Avatar
Default Re: Accord injectors not firing. Please help.
There's always the ground on the drivers side of the intake mani by the vacuum bungs that alot of people miss.
dglassmyer is offline   Reply With Quote
Old 02-11-2012, 12:23 AM   #3
Most likely you forgot the ground @dglassmyer is talking about. The thing is when I had that unhooked I got no spark...
gogydm is offline   Reply With Quote
Old 02-11-2012, 04:37 AM   #4
GhostAccord's Avatar
If it was the main G101 engine harness ground, as mentioned above, there would be no spark ether.
Make sure that the resistor box and injector connectors are plugged in tight and they are clean of debris. Also that they are getting battery voltage.
GhostAccord is offline   Reply With Quote
Old 02-11-2012, 06:29 AM   #5
phootbag's Avatar
How did you confirm the injectors aren't operating?
phootbag is offline   Reply With Quote
Old 02-11-2012, 07:12 PM   #6
I pulled them fuel rail and watched nothing come out as engine was cranked. The problem was solved though, it was the ground that connects to the manifold. Thanks for the very helpful information
Old 02-12-2012, 07:44 AM   #7
That's odd that you had spark to the cylinders in that case.
Oh well, Good to know that you were able to get the issue fixed with the info that you received.
Miss fire Cylinder #4 Dabears Honda Accord (1990 - 2002) 5 07-04-2016 07:48 AM
Number 1 Cylinder not firing JDMBrian Tech / Misc 6 03-14-2012 03:13 AM
h22 cylinder not firing msdh22 Honda Prelude 5 08-09-2010 02:46 PM
1991 accord ex wont start service1 Honda Accord (1990 - 2002) 6 08-27-2008 08:32 PM
My d15b8 will only fire on cylinders #3 and #4 wernhersey Honda Civic / Del Sol (1992 - 2000) 0 08-29-2006 05:47 PM
Tags
1992, 2000, 2001, 2003, 2005, 92, 97, accord, fire, firing, fuel, honda, injector, injectors, prelude
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
