Accord 2005 CEL 1902???
Hey guys i just checked out the CEL code, but i got 19 long flashes, and 2 short flashes. (there is a really short pause between the long and short, i think that MIGHT be a zero...)
So is either P1902 or P192 but i've check all over the place there is no such code.
The code came out after an oil change.
Any idea??
edit: hum can it also be P0192??
P0192 Fuel Pressure Sensor Circuit Low Voltage
Modified by codenamezero at 4:14 AM 5/16/2007
Any idea??
Re: Accord 2005 CEL 1902??? (codenamezero)
You're confusing the flash code numbers with the OBD-2 codes. They're separate lists.
Still, 19 long flashes isn't in any list I've seen. And the short pause isn't a zero. Try watching it again, or go to AutoZone & use a code reader.
Re: (codenamezero)
Any kind of parts stores like that? PepBoys, CanadianTire, ???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by codenamezero »</TD></TR><TR><TD CLASS="quote">... but i follow the code reading trick from RSX, it should be the same.</TD></TR></TABLE>What's that trick?
GsrVtec
10-19-2006 07:33 AM
