AC compressor wiring help....
I've owned my 92' cord for nearly 2 years now but the AC system was uninstalled by the last owner....I have absolutley everything for the reinstall:
1. Junkyard compressor (hope its good)
2. New Reciever/Dryer W/ Oriphus
3. New Seals (Green)
4. R-12 - R134a Retrofit kit
5. all hoses
6. Junkyard Condenser
7. AC Flush
8. shop will evacuate system
9. shop will Oil System
10. shop will fill system
Im currently stuck with the AC compressor right now because the connectors on the chassis for the system were cut by the previous owner....im in need of wire a wire diagram (from chassis to compressor) on this....it will be soldered and heatshrinked for temporary use....until I can get to a Pull-a-part for connectors.
5. all hoses
7. AC Flush
Re: AC compressor wiring help.... (Grandhustleman86)
here is a picture I've come across I belive the Red is the connector to the AC compressor but I have no Idea where the Blue and Black connector go....any input is helpful.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grandhustleman86 »</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
these wires and connectors are down in the driverside front below the headlight....if that helps.
After no help here I moved to mitchell and All-data and found that the Blue & Black is for the condenser fan....and the red is the power to the compressor clutch and it is grounded on itself hence the single wire connector.
JohnnyEF
06-07-2012 03:16 AM
Draggin99Si
12-29-2006 05:36 PM
slow99gsr
07-16-2006 03:04 PM
