ABS system - 14P and 26P connectors
Year - 1994
Model - Accord
Trying to diagnose my ABS system, know what the error code is. The Accord shop manual says to first check continuity between wire 4 and 11 on the 14P connector. Well the shop manual doesn't tell you which one 14P is, just says its the modulator connector. Does anyone know if this is the 14 point connector near the ABS pump or the ABS fuse box.
Also, where would the 26P connector be.
Model - Accord
Re: ABS system - 14P and 26P connectors (94accordsedan)
,,,,,,,the 14 plug is at the modulator unit,,, # 4 is a yellow wire # 11 is the black wire ,, modulator is on driver side under hood, frt fender,,,,,,,,,,,,the 26 p is at the abs control unit.it is located on rt side under dash,, passenger side kick panel,,
AllAboutHonda
05-03-2013 09:08 AM
ullman
11
07-21-2011 04:11 AM
