abs pump needs replacement on 1993 accord
Old 09-11-2008, 02:19 PM
dan123's Avatar
Default abs pump needs replacement on 1993 accord
I just purchased this 1993 accord, the abs warning light was on, i took it to a mechanic who stated i need a pump motor asm. he told me i hand to take it to a honda dealer for repair. i heard this is a 1000$ job. I checked some salvage yards, and found a pump for 150$. would this be a viable option? and what would labor be to replace the pump?
Old 09-11-2008, 06:38 PM
dtapia's Avatar
Default Re: abs pump needs replacement on 1993 accord (dan123)
most likely you are going to get some one else's problem what did it code for pump over run ? the time to repair the modulator and bleed system is about 2.5 hours is what we charge.
the reason they told you to take it to the dealer is we use a abs tester and it will cycle the system and purge the system of air in stages,i don't think their is any aftermarket tools that do that for your year.
steviez
01-31-2018 01:29 PM
gucci mane
01-04-2014 03:38 AM
mikey1968
11-05-2012 02:30 PM
Ihatecars
08-28-2006 10:05 AM
braggindad
06-27-2003 09:10 AM
Quick Reply: abs pump needs replacement on 1993 accord
