ABS light stays on - Honda-Tech
ABS light stays on
Old 07-07-2009, 10:32 AM   #1
New User
Default ABS light stays on
I have a 1996 Honda Accord EX Coupe. For the past year my ABS light has been coming on. It doesn't come on every single time I drive the car, but at least half the time. I orginally took it to the dealer who told me I would have to have the abs module replaced...too expensive for me.
I need to get it inspected and I don't know if it will pass inspection or not with the light on. Is there anyway I can pull a fuse or something to disable it? I can change my oil, plugs, filters, etc., but other than that I am at the mercy of a mechanic.
By the way, the car is all original, I have no aftermarket parts nor anything modified on the car.
Any help would be greatly appreciated.
Thanks,
Kevin
kpearson is offline   Reply With Quote
Old 07-07-2009, 01:44 PM   #2
19Accord97's Avatar
Default Re: ABS light stays on
The only way I could think of is to take apart the dash and pull the light bulb out. Or find out exactly what the sensor does for ther ABS system and see if you can simply trick it.
19Accord97 is offline   Reply With Quote
Old 07-07-2009, 01:53 PM   #3
He knows where you live!
TheMuffinMan's Avatar
Why not have it looked at at an independent Honda shop and see what they say the issue is. It may be simple. There's a "$3 ABS Fix" thread in the Accord FAQ.
TheMuffinMan is offline   Reply With Quote
Old 07-07-2009, 03:42 PM   #4
GlassJAw's Avatar
May pay for you to look at this thread on another forum and check what ABS code its throwing.
http://hondaswap.com/ecus-electronic...abs-how-61690/
See if you can reset the ABS so it stays off during the inspection
GlassJAw is offline   Reply With Quote
ABS Light On H22 CB Suspension & Brakes 0 10-01-2016 05:10 PM
2003 Accord ABS Light woszczy Engine Management and Tuning 0 11-21-2011 02:44 PM
Question about Brake/Lamp Inspection - California gsrob Acura Integra 3 12-23-2007 01:55 PM
Question about Brake/Lamp Inspection - California gsrob Honda / Acura 2 12-23-2007 10:26 AM
94 Accord ABS HELP!!!! skibum Honda Accord (1990 - 2002) 3 12-20-2007 05:15 PM
Tags
1994, 1996, 2003, abs, accord, bearens, car, fix, honda, light, put, reset, stays, suv, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
