ABS and BRAKE light on any ideas?
i started my car and my brake light came on then shortly after driving, my ABS light came on. it has been a couple of days now and they are still on at the same time (when i start the car for BRAKE light and then shortly after for the ABS light).
Any ideas on how to turn them off or get this problem fixed?
Thanks
Thanks
Re: ABS and BRAKE light on any ideas?
Thanks
Thanks
Honda incorporates a fluid level sensor in the cap.
P
If your ABS reservoir is empty, this might be the problem:
https://honda-tech.com/forums/honda-accord-1990-2002-2/fix-your-abs-system-%241-51-no-gimmicks-241713/
1 Post
Further to what P Adams and I have said, if the fluid levels are low it could also mean that the brake linings are low and may need replacement shortly.
Do your brakes squeel / screech whilst you're driving along the street? (usually this sound is the warning of low brake linings on the front and sometimes the rear if you have 4 wheel disc brakes)
front brakes are new and rears look good. fluids are all toped off!
Need some help on this!
Thanks
my front brake line was ripped so it kept spilling d fluid. check ur lines for any leaks or if its squished with sumthing. or maybe clogged lines.
HONDA_TYPE_R
11-30-2004 01:04 PM
