about the reverse lights
ok so im trying to find out why my reverse lights are not working
i changed the bulb and even checked the sockets which are fine
does anyone have any suggestions?
Re: about the reverse lights
also im so sorry for being so uneducated about cars . im learning about them little by little so please bare with my lack of knowledge
you should check the fuse box to the left of your clutch....that should actualy be where you go first always btw.....but yeaaa...check that out dude..
Find the reverse switch. Its bolted on top of the trans by the starter. Unplug the two wires that come out of the switch. Touch the two wires together. (on the harness). Turn the key to the "on" position. If the lights come on, you have a bad switch. If they dont, you have a popped fuse or a cut wire. Good luck!
KiDDD...
06-26-2012 10:00 PM
Killercocopuff
10-17-2011 07:55 AM
GregHr191
Transmission & Drivetrain
09-11-2009 10:15 AM
bpatterson6003
04-14-2009 10:00 PM
redline75
10
09-27-2006 10:03 AM
