99 vtech smoke issue
Old 04-29-2014, 10:20 AM
gumby87's Avatar
Default 99 vtech smoke issue
Hello !
Let me start by stating I know close to nothing about my Honda outside if what I've read in the manual, so I apologize for improper use of technical terms;
I've diagnosed fault codes indicating catalyst pressure below threshold (p0420). From the research I've done, I need to clear emission system and EGR valve of carbon build up. I'll admit I've been very busy, and money has been somewhat tight, so I haven't been able to do this. Now, I have a white smoke coming up from underneath the vehicle. I can only assume this is because of the carbon build up? I am also changing my oil every 1500-2000 miles now, as it seems to be burning very quickly.
What I am looking for are cost-effective solutions I can do myself, or the knowledge to have a discussion with a mechanic (without having to break the bank). If you would take a look at the image here: http://estore.honda.com/honda/images...S033B0200A.png The smoke is coming from the pipe above #18 & #17, that 'joint'.
Any advice is greatly appreciated.
Last edited by gumby87; 04-29-2014 at 10:33 AM. Reason: Update to be more informative
Old 04-29-2014, 01:29 PM
tim73's Avatar
Default Re: 99 vtech smoke issue
So its smoking from behind the engine? Are you sure it isnt an oil leak, and dripping down onto the exhaust? Say from the oil pressure sensor or VTEC?
Old 04-30-2014, 02:57 AM
gumby87's Avatar
After further inspection it appears to have been a leak. However, I am not entirely convinced the issue is solved. I've fixed the leak and should it begin to smoke again, I'll snap a picture and post it on here.
Thanks!
Old 05-02-2014, 02:25 AM
tim73's Avatar
Mine had the same issue, the VTEC was leaking due to a busted O ring. I replaced both VTEC orings, and it eventually stopped smoking. However, it did take a few weeks, before all teh oil burned off.
v8killaz
09-04-2010 05:29 PM
blackmfoggie
09-07-2007 07:34 PM
Dat_One_Si
10-22-2006 06:50 AM
greenhornet
10-27-2002 04:42 PM
advanracing62
09-24-2002 09:15 AM
Quick Reply: 99 vtech smoke issue
