99 V-6 Accord, Low flow EGR issue...
Old 07-13-2004, 03:28 PM
igawa's Avatar
Default 99 V-6 Accord, Low flow EGR issue...
My check engine lite came on: gave a "low flow" egr valve error. I have 91K miles on it now, but the EGR valve was already replaced at 65K.
Should I bolt on a new egr valve (cheap option) or have egr pipe kit installed per the "99-085 service bulletin" where the intake manifold is removed & everything is flushed, egr port is drilled, pipe inserted etc ??
In the case of plan B: can this be done with regular tools, or do I need to order the $72 pipe installation kit?? Please help
Old 07-13-2004, 03:52 PM
under advisement's Avatar
Default Re: 99 V-6 Accord, Low flow EGR issue... (igawa)
Have the pipe kit installed. If it already had a new valve put on it the port is probably plugged. A dealership usually only charges 1.5-2 hours to do it. If you are not mechanically inclined it would be worth the money to have a shop do it.
mhald
12-23-2007 04:43 AM
stefan*
05-11-2007 06:36 AM
erniecars
02-04-2006 10:22 PM
elpiar
09-27-2005 01:38 PM
comptechgsr2000
05-09-2002 10:50 PM
Quick Reply: 99 V-6 Accord, Low flow EGR issue...
