99 accord coupe front end vibration - Honda-Tech
Old 02-21-2012, 05:26 PM   #1
Default 99 accord coupe front end vibration
This is my third accord and am having difficulty fixing my steering wheel vibration. Miles are 111000, new tires, fresh rotation and balance. I am getting a vibration at about 70 MPH, under throttle, letting off etc. I thought for sure it was a tire / balance issue but am now stumped.
Is there anything on these 6th gens that is a common issue in the front end? It does have an aftermarket axle on the left side. It is a one owner that has never been wrecked.
Next is putting it on a lift to check the bearings etc. Just looking for obvious issues to check first.
BTW, any good sources for hub/bearing assemblies? Might as well change them at 111000 miles....
1991EX is offline   Reply With Quote
Old 02-22-2012, 07:01 PM   #2
ricebike's Avatar
Default Re: 99 accord coupe front end vibration
did it vibrate before the new tires/ rotation/ balance job?
and you rotate the tires front-to-back to make sure that the tire/balance issue is ruled out?
ya, putting it on a lift or up in the driveway to check all bushings/joints/tie rods/bearings is a good check as well...
ricebike is offline   Reply With Quote
Old 02-24-2012, 06:02 AM   #3
Thanks. So far I have balanced / rotated and even tried another set of wheels/tires from another accord. After putting it on the lift I noticed that the replaced (newer) axle shaft has minor play (rotational) in it. Everything else is tight.
My plan right now is to install new brakes / rotors, then tranny mount, then the left shaft. If that does not fix it I will live with a 70+ mph vibration. I have done a complete tune-up to include a new dizzy to fix an internal leak. The engine runs very smooth, shifts great, so I am running out of things to relate to a vibration.
thanks for the reply!
2003 Accord Vibration dtrophy Honda Accord & Crosstour (2003 - Current) 6 08-19-2016 06:53 PM
Accord Vibration Mazzy0063 Honda Accord & Crosstour (2003 - Current) 8 11-29-2012 02:02 PM
d16z6 and more for sale. vtecspeed1320 Mid-West (Sales) 1 04-24-2006 11:23 AM
95 Accord Vibration psadler Honda Accord (1990 - 2002) 4 12-28-2005 07:01 PM
Front End Vibration 92integraVTECgsr Acura Integra 11 08-03-2005 06:40 AM
Tags
1999, 2000, 6th, 99, accord, civic, coupe, end, front, frontend, frony, gen, honda, shaking, tires, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
