'99 2.3L oil pump gasket
Old 07-19-2012, 04:22 PM
tobytigger's Avatar
Default '99 2.3L oil pump gasket
I've got 207K miles on my '99 4 cyl vtec and have the timing belt off. Replaced the cam, crank and balancer seals. I definitely had cam shaft seal leak with oil dripping down into lower cover. I think the balancer seal was also leaking but it's hard to tell if the oil pump seal is leaking or if its just some sludge from top of engine. Can I just remove the front plate of the pump and replace the seal or is it more involved?
Chargerhemi06
12-04-2014 05:43 PM
tony_2018
09-04-2014 07:18 AM
johnboy033
11-09-2007 11:30 AM
MugenHonda
02-14-2007 07:04 PM
snatch
12
03-15-2005 10:12 AM
Quick Reply: '99 2.3L oil pump gasket
