98 HONDA ACCORD TUNE UP... - Honda-Tech
Old 06-09-2006, 08:19 AM   #1
execute007's Avatar
Default 98 HONDA ACCORD TUNE UP...
1998 hond accord, 96k miles. I want to do a complete tune up on this car. Does anyone have a writeup on what i should buy and how to do the tune up?
Thanks
execute007 is offline   Reply With Quote
Old 06-09-2006, 08:24 AM   #2
S CARTER's Avatar
Default Re: 98 HONDA ACCORD TUNE UP... (execute007)
V6 or 4 cylinder?
S CARTER is offline   Reply With Quote
Old 06-09-2006, 10:25 AM   #3
execute007's Avatar
Default Re: 98 HONDA ACCORD TUNE UP... (S CARTER)
v4..
Old 06-09-2006, 10:55 AM   #4
mattf22b1's Avatar
ok..rotate tires change oil and oil filter change fuel filter coolant flush, clutch fluid brake fluid, transmission fluid, power steering fluid, change distributor cap and rotor, change spark plugs and wires. timing belt and all drive belts. Check timing, compression, and do a leak-down test. check brake pads and rotors, change windshield wipers if necessary. re-do all grounds valve cover vtec solenoid engine ground etc...clean motor and do a motor flush, involves putting in liquid with you old oil nd running the car for 10 minutes before changing oil, can use sea foam if you want to clean up the carbon build up.
thats all i can think of right now, and pretty much all ofr this can be found at your local autozone, if you need/want honda specific parts try http://www.tasauto.com
mattf22b1 is offline   Reply With Quote
96 accord Corey Millsap Honda Accord (1990 - 2002) 6 12-24-2015 12:47 PM
How do you tune set up a APEXI V-AFC?? Gomdohree Acura Integra 27 05-02-2008 02:11 PM
Need Help with 2006 Honda Accord LX-V6 Tune Up phandovan Honda Accord (1990 - 2002) 1 02-06-2007 12:06 AM
f23 turbo tune? accord01 Honda Accord (1990 - 2002) 1 11-28-2006 08:56 PM
50,000 mi. TUNE UP ????? RUBZERK Honda Accord (1990 - 2002) 14 09-18-2003 10:01 AM
Tags
1998, 2001, 98, 99, accord, accords, brake, fluid, flush, honda, included, parts, tune, tuned, tuneup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
