98 honda accord auto transmission problems
Old 05-27-2009, 11:05 AM
New User
XTYPES's Avatar
Icon2 98 honda accord auto transmission problems
i have a 98 honda accord lx auto
lately i;m having trouble getting the
car to shift gears. on automatics when
you start the car you step on the brakes
then shift from park to whatever but it
takes 5 to 10 tries before it shifts, but
when it shifts the car drives just fine.
i'm not sure what is causing the problems
but if some could help me out with an idea
about what is wrong it would be great.
Old 06-02-2009, 09:00 AM
New User
asyed916's Avatar
Default Re: 98 honda accord auto transmission problems
try having the transmission fluid drained... NOT FLUSHED!!...
Old 06-02-2009, 01:06 PM
rjHella's Avatar
do you start from 1st gear just like you would in a manual?
Old 07-16-2009, 03:13 PM
rjHella's Avatar
bump.
is it common to shift your auto as if it were a manual?
pros &cons please??
im asking this to the general public not the op.
Old 07-16-2009, 03:40 PM
SlimNubster's Avatar
The 98-02 series (primarily the 98-00) were plagued with transmission problems. If you're the registered owner of your Accord, you might wanna take it to your local Honda Service dept. so that they can take a look and fix/replace it.
I do believe there was some sort of recall at some point.
Old 07-19-2009, 12:09 PM
YeuEmMaiMai's Avatar
recall was for 2nd physical gear overheat. 00-01 accords were covered under an extended 7 yr 100K mile warranty. ALL of these cars are past the warranty period now.
98,99 and 02 cars had no warranty although Honda did fix a lot of them under goodwiill at no cost or significantly reduced cost.
Tyler Crumbley
04-30-2018 06:44 AM
phatphunk
03-22-2015 06:58 AM
matcauthon19
06-07-2014 02:58 PM
CivicK20
11-09-2006 05:24 PM
loccsta187
01-12-2006 03:35 AM
Quick Reply: 98 honda accord auto transmission problems
