98 civic B18A1 with trany swap
please remove this post
hello, i posted this in the wrong area by mistake, i cant seem to delete, if i could get a lil help i would greatly appreciate it... thank you,Brian
Modified by 4Door Life at 8:03 PM 5/23/2006
2010 Honda-Tech Poker champion
Re: 98 civic B18A1 with trany swap (4Door Life)
Good luck with your swap. May have better luck with help if you were to post this in the civic frum instead of the accord forum though.
Re: 98 civic B18A1 with trany swap (Noles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noles »</TD></TR><TR><TD CLASS="quote">Good luck with your swap. May have better luck with help if you were to post this in the civic frum instead of the accord forum though.</TD></TR></TABLE>
thank's, was up to late last night didnt notice i did that... can i move this over to the right forum or is it to late...??
H-T Order of Merit
I already reported it asking for it to be moved but it hasn't yet. You can't do it yourself but you could either...
A. click "Edit" on your first post and click "Delete" to delete this thread, then make a new thread in the correct forum or...
B. PM a moderator and ask if they can move it over to the correct forum for you.
If you chose A, I suggest just highlighting, copying and pasting everything into the new thread rather than retyping it all again.
Re: 98 civic B18A1 with trany swap (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">I already reported it asking for it to be moved but it hasn't yet. You can't do it yourself but you could either...
If you chose A, I suggest just highlighting, copying and pasting everything into the new thread rather than retyping it all again.</TD></TR></TABLE>
thank you, i will do A... it sounds like it will be the easyiest way...
thank you again, i have it posted in the right area now, i have a note to please delete this post because i dont belive i can... again thank you Noles and TouringAccord
blkknight619
02-07-2005 03:21 PM
imbigmikey
04-19-2004 12:35 PM
