98 accord v6 wit P1457 Evap pending code!!
Old 09-18-2005, 08:50 AM
accordv6turbo!!!'s Avatar
Default 98 accord v6 wit P1457 Evap pending code!!
what's pplz!
i have hooked up a scanner to check for any codes present. none came up, but when i went under pending codes, a p1457 code came up, (leak near charcoal canister). i check all hoses for cracks, loose, or missing. all hose are ok. then, i replaced canister purge solenoid valve, evap bypass solenoid. then i reseted the pcm by removing the negative terminal. the code was clear! then i drove around for a couple of days. hooked a scanner again, and the code came as pending again. should i replace the charcoal canister or vent shut-off solenoid valve? any body wit suggestion would be apprciated. someone help me plz!!!
Old 09-18-2005, 08:53 AM
twkdCD595's Avatar
Default Re: 98 accord v6 wit P1457 Evap pending code!! (accordv6turbo!!!)
have you check your gas cap... when the seal on them is bad you will get an small leak evap code.
Old 09-18-2005, 12:37 PM
yea gas cap was the first thing i replaced about couple months ago.
Old 09-18-2005, 12:48 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordv6turbo!!! &raquo;</TD></TR><TR><TD CLASS="quote"> a p1457 code came up,</TD></TR></TABLE>
The first thing I would check is the canister vent shut valve.
Old 09-18-2005, 12:49 PM
Chiovnidca's Avatar
Default Re: 98 accord v6 wit P1457 Evap pending code!! (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">have you check your gas cap... when the seal on them is bad you will get an small leak evap code.</TD></TR></TABLE>
A loose or missing gas cap will usually put up a p1456 code.
Old 09-19-2005, 10:33 AM
i hooked a mac scan tool, very expensive but any way, it gave me a p1457 pending code not p1456 and already recently put a new honda gas cap. any other suggestions??
Old 09-19-2005, 10:36 AM
Default Re: (accordv6turbo!!!)
it says that the leak is coming from somewhere near the charcoal canister, plus i have a new gas cap put in recently thanks though!
Old 09-19-2005, 12:46 PM
JimBlake's Avatar
All those things that you've already replaced; did you test any of them to see if they were really bad? You could've bought a MityVac instead...
When mine got P1457 it turned out to be the vent-shut valve. Mine was corroded & it didn't even click when I jumpered it directly to the battery. Normally you'd use a MityVac to see if it opens & closes properly.
Check out https://honda-tech.com/zero...63913 & scroll down to my post with stuff to check for P1457. I should say that's for a '98 4-cyl; I don't know whether anything's changed for the V-6.
Old 09-19-2005, 01:57 PM
Chiovnidca's Avatar
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote"> I should say that's for a '98 4-cyl; I don't know whether anything's changed for the V-6.</TD></TR></TABLE>
They're pretty much the same.
Old 09-19-2005, 02:27 PM
hondadude's Avatar
Try this link it's a PDF zip file
http://members.troublecodes.ne...7.zip
brad8266
07-12-2022 10:28 AM
teler86
12
02-20-2007 01:46 PM
Legendaryyaj
03-03-2006 06:23 AM
social_control
11-18-2003 04:39 AM
mitch48
06-02-2003 07:28 AM
Quick Reply: 98 accord v6 wit P1457 Evap pending code!!
