98 Accord V6 EGR problem - Honda-Tech
Old 11-24-2006, 01:40 PM   #1
tjlmbklr's Avatar
Default 98 Accord V6 EGR problem
I had the "engine" light come on about 6 months ago. I had Autozone check the code. It came up "EGR valve insufficiant flow" or something close to that. I bought an EGR vavle factory direct off of ebay and put it in. I cleared the code (disconnect battery). But after driving a few miles the light came back on. I had Autozone check it again and it came back the same. What am I missing? It is just a plug and 2 bolts.
tjlmbklr is offline   Reply With Quote
Old 11-24-2006, 05:00 PM   #2
Default Re: 98 Accord V6 EGR problem (tjlmbklr)
That's a common problem for V6 Hondas. There's a simple repair procedure though.. All you have to do is clean out the EGR port on the intake manifold. To do this you'll have to remove the intake manifold from the head and drill out the clogged EGR port. If you go to a Honda dealer, they'll check to see if you're still covered under that extended warranty. If not, it'll cost you some good money. Might as well do it yourself. The dealer will usually sell you a kit that needs to be installed. I find it much better if you just drill out the clogged port. There's really no difference in installing the stupid kit. I've seen cars come back 50K miles later clogged again.. So save yourself some money just clean out your own EGR port..
PnX-R is offline   Reply With Quote
Old 11-24-2006, 05:36 PM   #3
hondadude's Avatar
Here's some more help for you.
http://members.troublecodes.ne...5.gif
hondadude is offline   Reply With Quote
Faulty EGR Valve reading firaga21 Honda Prelude 3 10-13-2009 03:37 PM
CEL Check Engine Light staying lit... 93blulude Honda Prelude 1 07-11-2008 03:41 PM
EGR Troubleshooting? ProLineDesigns Honda Accord (1990 - 2002) 3 09-23-2007 06:23 AM
Engine light - EGR flow insufficient srburk Honda Accord (1990 - 2002) 11 01-29-2007 04:01 PM
Egr value engine light question? chieny Honda Prelude 6 12-02-2005 12:29 PM
Tags
98, accord, clean, cleaning, clogged, correct, disconnect, egr, head, honda, issues, plugs, port, problem, problems, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
