starting without coolant?
Old 01-10-2010, 10:30 PM
dleccord's Avatar
Default starting without coolant?
can you start a car for 30 seconds without coolant on a cold morning?
Old 01-10-2010, 10:56 PM
19Accord97's Avatar
Default Re: starting without coolant?
Why?
Old 01-10-2010, 11:01 PM
HT White Ops
Eran's Avatar
Originally Posted by 19Accord97
Why?
Because he probably already did it.
Old 01-10-2010, 11:03 PM
dleccord's Avatar
im dong my timing belt and i just want to run it before i put everything back together and incase theres a water pump leak, there wouldnt be coolant draining out of the water pump in case i have to open it up to inspect.
Old 01-10-2010, 11:15 PM
Davidss's Avatar
Yeah it's fine to run it for 30 seconds. But I wouldn't run it much longer than that. It's nice to get to fire it up to make sure everything is ok before you finish putting everything back together!
Old 01-10-2010, 11:19 PM
dleccord's Avatar
thats what i figured too since theres not water circulating the engine while its cold anyways.
but i could be wrong that there needs to be water in the block.
Old 01-11-2010, 10:18 AM
JLUDE01's Avatar
I can't see how it could hurt anything.
Old 01-11-2010, 12:54 PM
dpetro1's Avatar
how do you plan to check for a coolant leak if there is no coolant in the system to begin with??
also, even though im sure 30 seconds wouldnt hurt much, the water pump is lubricated by coolant so basically you would be running your brand new pump with no lube
Old 01-11-2010, 01:08 PM
cstone's Avatar
^this^
There is some coolant flowing through the block when the engine is cold, just not much. Thats what a T-Stat's bypass is for...
Like he said it probably wont do any serious damage. But its extra wear on the water pump most likely.
Old 01-11-2010, 06:59 PM
dleccord's Avatar
perfect answer. thanks.
justint7121
11-21-2010 09:46 PM
niceprelude
02-15-2009 10:20 PM
wedtm
03-26-2008 07:59 PM
Lude-Lee
02-18-2008 07:50 PM
erikiksaz1
08-27-2006 07:45 PM
Quick Reply: starting without coolant?
