Old 04-06-2015, 09:46 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Alternator belt squeak on startup
Old 08-22-2009, 07:05 PM
JasonST's Avatar
Default Alternator belt squeak on startup
Hey Guys, I recently changed the timing belt in my friends 98 LX f23a1. Everything went well but when I was all done the alternator belt quickly chirps on startup then goes away. It's been annoying him so I went over to fix it today by tightening up the belt, but no matter how tight (within reason) I get it, it still squeeks only for a quick sec when the engine starts. I'm really confused as to why the belt squeaks now and that it didn't before I changed his timing belt. All I did to it was take it off, put it back on and retension it. I am going to try and replace it tomorrow but if that still doesn't fix it, I was wondering what else could be the culprit? Any help would be appreciated thanks .
-Jason
Old 08-22-2009, 07:29 PM
YeuEmMaiMai's Avatar
Default Re: Alternator belt squeak on startup
take belt off clean pully inspect belt and reinstall
Old 08-22-2009, 08:05 PM
JasonST's Avatar
Yeah I didn't think there was much that could go wrong. I'll get a new belt and clean the pulleys tomorrow and keep ya posted. Thanks.
-Jason
Old 08-22-2009, 08:11 PM
GhostAccord's Avatar
Adjustment and/or replacement is the way to go with squeaky accessory belts.
Old 08-22-2009, 09:23 PM
New User
vecken's Avatar
i had this issue except it was far worse than yours, it would squeal non stop. it turned out that the tightener bolt under the alternator has come completely out, loosen the mount bolts on the alternator then tighten the adjustment bolt down as much as you can without stretching the belt. then re-tighten the mounting bolts. fixed it for me and not a squeal since.
Old 08-22-2009, 11:41 PM
nus_dogg's Avatar
When mine does that, I tighten them up so they won't squeak anymore.
Old 08-23-2009, 08:41 PM
02 accord's Avatar
It could be the power steering belt that's squeaking. Tighten that one too.
Old 08-24-2009, 09:07 AM
Janet@bisimoto's Avatar
It would be more time effective to simply replace the belt.
Old 09-03-2009, 12:37 PM
9KRevLimitDC2's Avatar
I had this problem too except it was a brand new oem honda alt. belt? Anyone have any advice?
Old 09-03-2009, 05:23 PM
02 accord's Avatar
Tighten it up.
Old 09-03-2009, 11:32 PM
Ed ke6bnl's Avatar
I tighten them up mine were new and squealling and they seem to stretch a lot when new tightened them up and not a problem now
Old 09-04-2009, 08:15 AM
nicolaselias's Avatar
no matter how much I tightened my power steering belt, it wouldnt shut up on startup..
eventually sprayed it with some silicone spray and it shut it up well..
Old 09-04-2013, 08:16 PM
crazyhouse2011's Avatar
Mine does that all the time. Turns out it was the bearings in the alternator failing. You should check that too. I would do a voltage test both at your battery and at your alternator. See if your alternator is failing. If so, get that muhfugga up outta there.
Old 09-05-2013, 02:36 PM
gtaylor318's Avatar
Mine been doing the squealing at start up every since I had timing belt replaced to been over a year maybe two 1991 honda accord dx
Old 09-06-2013, 10:02 AM
2001accord's Avatar
can try spraying it with that "anti-slip" spray to see if that helps since tightening doesn't seem to work for you
snapper1978
10-18-2006 09:21 AM
mohsinkhan35
09-02-2005 06:21 PM
cr-x si
03-23-2003 04:43 AM
Jason91CRX7
06-16-2002 02:08 AM
blayzenazn
02-18-2002 07:51 AM
Quick Reply: Alternator belt squeak on startup
