97 honda accord h23a no fire - Honda-Tech
Old 09-11-2011, 02:18 PM   #1
Default 97 honda accord h23a no fire
i got a 07 accord h23a swapped but is getting no fire. i converted it to a obd1 harness with a obd2 to obd1 ecu harness. and the harness is external coil and the car is internal but no fire. and ive replace the distributor and everything internal to the dizzy but nothing and the fuel pumps kicking on so dnt beleave the main relays bad. ive checked the trans, manifold and valve cover grounds and all are secure so im at a stopping point so any thoughts welcome.
h22accord101 is offline   Reply With Quote
Old 09-11-2011, 09:07 PM   #2
rival12's Avatar
Default Re: 97 honda accord h23a no fire
Quote:
07? or 97?
Very Different. Does it crank?
rival12 is offline   Reply With Quote
Old 09-13-2011, 05:12 PM   #3
sry 97 and yea itll turn over just no fire and fuel pump is kicking on and ive replaced the distributor and made it internal coil withnew coil cap button plugs and wires and still nothing. only thing is be4 i replaced that stuff it had a msd external coil and i started it up and had a lil miss so i thought i wired it up wrong so i switched the 2 wires and that ended up being wrong and it fried the coil and i havent got fire since.
Old 09-15-2011, 07:53 PM   #4
i talked to a few friends and they say to check the coil hot wire and see if its getting a signal if it isthen most likely its the coil but if its not getting any signal then they think its my ecu so do i check with ign on or turn the car over any thoughts on this
Old 09-17-2011, 05:11 PM   #5
ok ive check the hot wire to coil and it has no power when ign on or turning over and the distributor plug has ground but no power to anywires could this be the ecu or any other possable things. all the fuses r good
new h2b swap... stuck on clearing 2 cels. dsl77 Hybrid / Engine Swaps 20 08-12-2015 03:49 PM
Obd2a to obd1 dizzy wiring 1native Honda Accord (1990 - 2002) 0 06-23-2015 01:16 PM
obd2 h23a to 94 lx accord f22b2 h22god Honda Accord (1990 - 2002) 0 02-18-2013 10:03 AM
97 accord with h23a vtec fire issues h22accord101 Honda Accord (1990 - 2002) 2 01-10-2012 08:00 PM
Noob with Ls/vtec needs help Wylee_M Tech / Misc 14 02-18-2011 05:30 AM
Tags
1997, 97, accord, coil, computer, external, fire, ground, h23a, honda, hot, location, test, transmition, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
