97 Accord Valve Adjustment? - Honda-Tech
Old 01-10-2007, 07:12 PM   #1
Stevenm2k3's Avatar
Default 97 Accord Valve Adjustment?
I have seen some DIY'ers online about valve adjustments, but it wasn't much more than what I have already done.
So here's the problem. I have a 97 Accord, F22B1... not clear on the last number.. but i think thats right(too lazy to go look again...) well the rockers are pingin pretty bad. I opened up the valve cover, placed out lots of towels.... and cranked 'er up. Of course, oil rained out like a misty breaze... hmmm yum! well... I took a tube to each valve and the other end to my ear to hear which onces are pingin... Id turn the car off... set the cam so that the valve was closed on each lock nut I loosed. Then tightened the screw with a flat head screwdriver.... well... needless to say.. the pinging didnt stop. One time I even tightened it to much and the engine was bogging like the exhaust valve wasnt closing(obviously from over tightening). Well... So I loosend it up to the last setting where it wasn't bogging. Still noisy... well.... so I get online to find a DIY'er... and it said something about a special tool.. but that was for the DOHC h22 head.. i dont know if its the same set up or not... mine is a SOHC.. so.. I don't know...
If you guys got any ideas, lemme know. I'm bout ready to pull the head off my other honda and swap them. They are both f22 sohc's. Same head... but id rather just fix it... lemme know if you got any ideas to eleminate the pinging.. its quite annoying.
Modified by Stevenm2k3 at 1:34 PM 1/11/2007
Stevenm2k3 is offline   Reply With Quote
Old 01-10-2007, 07:14 PM   #2
hondadude's Avatar
Default Re: 97 Accord Valve Adjustment? (Stevenm2k3)
I see a burnt valve in your near future
hondadude is offline   Reply With Quote
Old 01-10-2007, 07:22 PM   #3
Stevenm2k3's Avatar
Default Re: 97 Accord Valve Adjustment? (hondadude)
Quote:
Ooook.... so whats that supposed to mean? I'm looking for help, not dumbass remarks..
Old 01-10-2007, 08:03 PM   #4
iam7head's Avatar
Quote:
simply/general note about valve lash adjustment
too tight=burnt valve
too losse=tipping
iam7head is offline   Reply With Quote
Old 01-10-2007, 09:19 PM   #5
JimBlake's Avatar
... If you guys got any ideas, lemme know...
My idea is that nowhere in your post do you say anything about using feeler gauges to actually measure the valve clearance. If you don't do that you're asking for trouble.
It's more difficult to reach the adjusters on a DOHC engine, so there's a special tool. It's basically a socket with a screwdriver in the center so you can hold the adjuster while tightening the jam nut. On your SOHC engine you can do that with a normal wrench & screwdriver.
JimBlake is offline   Reply With Quote
Old 01-11-2007, 05:21 AM   #6
H-T Order of Merit
TouringAccord's Avatar
Quote:
I was thinking the same thing as I was reading his post.
Here is a good write-up on how to do a valve adjustment, no pictures but well explained I think.
Valve Adjustment
There was a post on AD that showed scans of the Helm manual but the scans have been removed.
TouringAccord is offline   Reply With Quote
Old 01-11-2007, 01:31 PM   #7
Stevenm2k3's Avatar
Well, I was doing it by ear.. to see when the sound stopped.. but.. it never did. I'm gonna get a feeler gauge... and see if that helps. But still.. even if I tightened it to much, the pinging should have stopped right??
Any suggestions to what I should do if the pinging doesnt stop?? or what the hell else the pinging noise could be?
Old 01-11-2007, 02:52 PM   #8
JimBlake's Avatar
... or what the hell else the pinging noise could be?
Maybe it was simply more than one valve adjustment being off. If they're nearby, you can still only adjust one at a time, so it never goes away by that method.
If that's not it, you should try to pinpoint the location of the noise.
Spark knock? Check your spark timing.
Old 01-11-2007, 03:13 PM   #9
Stevenm2k3's Avatar
I already pinpointed the sound to 3 different exhaust valves... the rest were fine...
Old 01-11-2007, 04:25 PM   #10
adams07's Avatar
Everyone be nice to Steven. He's sensitive. I've heard the noise myself and the tap is coming from the top rocker to valve contact even at zero lash. Doesn't sound like spark knock or pinging althought it's not out of the question because he's running a bad O2 with who knows what kind of fuel/air mixture.
adams07 is offline   Reply With Quote
Old 01-11-2007, 04:33 PM   #11
hondadude's Avatar
You are not being very thoughtful about the way the engine works! DUMBASS
And BTW don't you think it might just be a little easier to swap out valve trains as opposed to swapping heads?? DUMBASS
Old 01-11-2007, 05:00 PM   #12
joenoreason's Avatar
Adjusting a valve is such a ridiculously minute measurement... People actually attempt to adjust them by ear?
joenoreason is offline   Reply With Quote
Old 01-11-2007, 05:15 PM   #13
adams07's Avatar
I'm used to adjusting the valves on a sbc, I'm guessing these honda motors are more presise?
Old 01-11-2007, 05:27 PM   #14
Default Re: (adams07)
I mean we are talking about measurements in the thousandths. I don't see how anyone could do it by ear or just do it by eye because they've done it a million times. At least not correctly. But then again I'm no mechanic so don't listen to me.
Old 01-11-2007, 08:20 PM   #15
JimBlake's Avatar
Quote:
What's an sbc? All the car's I've ever owned need to be adjusted by measurement.
Some were shim&bucket, so once they're correct they stay that way almost forever.
Old 01-11-2007, 08:48 PM   #16
Default Re: (JimBlake)
small block chevy probably
Old 01-11-2007, 08:57 PM   #17
adams07's Avatar
haha ya small block chevy. Now you see where I'm coming from.
Old 01-11-2007, 10:14 PM   #18
JimBlake's Avatar
Default Re: (joenoreason)
Quote:
OK. My dad used to adjust valves by ear on a 56 chevy when I was a kid.
94-97 Accord D.S. Lock Actuator - Microswitch Repair/Reset? MaoMobiles Honda Accord (1990 - 2002) 30 07-15-2016 11:00 AM
CRV '12 open door, warning chime won't stop Naje Honda Element & CR-V 0 04-01-2015 01:44 PM
removing studs from the head? Stevenm122084 Honda Accord (1990 - 2002) 1 07-01-2006 11:47 PM
'94 Accord clicking noise when making left turns rcc80 Honda Accord (1990 - 2002) 6 04-20-2005 05:20 PM
Replacing halfshafts on a 1997 Accord. Calean007 Honda Accord (1990 - 2002) 9 03-12-2005 07:34 AM
Tags
1997, 1999, 97, accord, adjust, adjusting, adjustment, adjustments, avoid, honda, knock, lx, number, proceedure, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
