95 Accord EX Automatic VTEC not working!!!
Old 01-11-2007, 03:00 PM
1SIKZ31's Avatar
Default 95 Accord EX Automatic VTEC not working!!!
The motor is not getting in to VTEC.
The speedometer doesnt work, and a local tuner shop told us that the speedometer has something to do with the VTEC not working?
Where is the Speedometer sensor located?
They told us you open the hood (auto tranny by the way) and look at where the transmission and engine meet up and somewhere under the distributor is the sensor.
Is this correct?
We cant find it!
Old 01-11-2007, 03:37 PM
hondadude's Avatar
Default Re: 95 Accord EX Automatic VTEC not working!!! (1SIKZ31)
Look straight down from the point where the throttle body meets the air snorkle tube, it has a 3 wire connector going to the top of the differential housing.
Yes, I do believe the VSS is important to helping the V-Tec system work correctly
Old 01-11-2007, 09:15 PM
1SIKZ31's Avatar
Default Re: 95 Accord EX Automatic VTEC not working!!! (hondadude)
The speed sensor was replaced, VTEC NOW WORKS!!
BUT...
After a couple of test runs on the freeway... we stopped and turned around to head a diffrent direction, on the way to a friends house, it stopped working!
The transmission when at WOT would only go to 4k and then change gears very early... But we let the car sit for a while and all of a sudden that problem went away and so far so good and its working again.
weird!
stehigs321
15
03-01-2019 05:16 PM
Darren Warner
07-10-2009 11:53 AM
young geezer
05-21-2009 06:20 PM
HONDRETTI
11-20-2007 10:20 AM
jagged4698
01-25-2004 06:09 PM
Quick Reply: 95 Accord EX Automatic VTEC not working!!!
