H22a problems.
H22a problems.
Ooops, posted this in the wrong section first.
So long story short. i dropped a jdm H22A into my accord over the summer. it hasn't run right since, (first motor work on new motor, i grew up with old V8's), it has been running extremely rich and had a lack of power. We tried everything. wiring, timing, sensors... nothing helped. back in November when we went to fix the timing the belt broke, and i finally got it fixed last night, had to use a friends p28 computer.
Now it runs perfect, starts up like a dream, the only problem... it falls flat on its face at 2,000 rpm.
anybody ever had this problem? any ideas on what it is? i'm pretty positive its a sensor problem, it would just save a lot of time if i knew what sensor.
thanks.
thanks.
Re: H22a problems.
Just out of curiosity, what ECU were you running before you put the P28 in it?
To solve your new problem you should get an OBD1 P13 ecu or a chipped/Socketed OBD1 (P06/P28) ECU that is tuned for your H22.
borrego_cd5
04-27-2011 10:00 PM
turbosol18
11-03-2007 05:38 AM
