97 Accord se Low hot idle
Hello,
My 97 accord has low idle when at operating temp. The idle is around 550ish. It's the same in Park, Neutral and In gear. Switching from drive to neutral does not bring the Rpms back up, likewise switching from park or neutral to drive doesn't bring the Rpms lower (at operating temp when the Rpms are 550).
The problem seems to be temporarily cured with a high way run. Also when in stopped in gear, a quick gas pedal press (on and off) bogs the car a little when the Rpms go down.
Any thoughs?
The Rpms do not "hunt"
UPDATE: I cleaned my throttle body valves and etc, as described in the guide and the problem went away for now. Car idles smoother too.
Any thoughs?
Re: 97 Accord se Low hot idle
Mishako129
08-27-2015 10:41 PM
colvin84
05-05-2007 05:47 PM
