97 accord no start just click - Honda-Tech
Old 07-07-2011, 08:20 PM   #1
Default 97 accord no start just click
I have try searching around the forum and I can not find the answer. The car will start like early in the morning and after I go to a place and turn the car off and than try to turn it back on it would not start but I do hear a clicking noise. BUT if I start the car with my remote starter instead of the key it will always start no matter what. I have replace the starter, spark plugs, distributor cap, air filter, tested the battery, and i know it cannot be the starter or battery since the car will start just fine if I use my remote starter.
Can anyone help? Sorry forgot to mention it is a 1997 accord lx non vtech i4
One more thing sometimes when I turn off the car and everything I made sure is off like the A/C and stuff, so I turn off the car and remove the key but my car sound like it is still running.
vi3tzkidd is offline   Reply With Quote
Old 07-07-2011, 08:32 PM   #2
dglassmyer's Avatar
Default Re: 97 accord no start just click
Ignition switch?
dglassmyer is offline   Reply With Quote
Old 07-07-2011, 08:33 PM   #3
I thought with an ignition switch it still try to crank but wont start? My car does not even try to crank all I hear is a click.
Old 07-07-2011, 08:49 PM   #4
dglassmyer's Avatar
Icon5 Re: 97 accord no start just click
Well the sound your likely hearing is the gear inside your starter that engages the cogs on the flywheel being pushed forward to turn the motor over, however if your starter is bad, such as a flat spot on the commontator or weak springs pushing the brushes it will just click as power can't transfer through the starter, therefore it wont spin.
If that were the case I would say you have a bad starter.
But since you stated it will remote start consistently that can't be the case, try using the point your remote start plugs in and troubleshooting upstream of it for issues, ending with the ignition switch
Old 07-07-2011, 08:54 PM   #5
Yeah I will probably test the igintion switch tomorrow with a continuity tester.
Old 07-07-2011, 09:01 PM   #6
dglassmyer's Avatar
I just mentioned this to another guy and its basic but also make sure your ground cable is secure and in good shape
Old 07-07-2011, 09:52 PM   #7
Manual or Automatic?
gogydm is offline   Reply With Quote
Old 07-07-2011, 10:24 PM   #8
it is an automatic
Old 07-08-2011, 07:03 PM   #9
nus_dogg's Avatar
Probably something in the primary starting circuit.
nus_dogg is offline   Reply With Quote
Old 07-08-2011, 09:45 PM   #10
You have a bad starter. I had the same problem with mine. It happens at random, there is no logic or reason behind it. Get the starter tested.
chikin pickle is offline   Reply With Quote
Old 07-08-2011, 10:25 PM   #11
Here is a link form a different forum http://www.cd5tuner.com/vbb/showthread.php?t=5322.
Old 07-14-2011, 11:42 AM   #12
it ended up being the ignition switch but luckily honda replace it for free so really didnt cost me anything but thanks for all the help
How to test my starter motor gooblinn258 Acura Integra 8 12-16-2013 09:23 AM
HONDA CIVIC WONT START!! STARTER CLICKS. NEED HELP ASAP!! 99Whiteekferio Honda Civic / Del Sol (1992 - 2000) 28 11-05-2013 02:35 AM
Accord wont start when warmed up after being turned off... jwicecold Honda Accord (1990 - 2002) 7 08-06-2011 11:00 PM
98 accord....battery connections or starter? Please Help Desiss Honda Accord (1990 - 2002) 2 11-18-2008 04:41 AM
97 Accord SE starter problem? adiosbeautiful Honda Accord (1990 - 2002) 2 12-27-2005 04:10 PM
Tags
97, accord, car, click, clicks, honda, justs, klick, noise, remote, sound, start, starter, switch, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
