97 Accord Lx timing belt?
Old 01-21-2009, 08:33 AM
mouab18c1's Avatar
Icon2 97 Accord Lx timing belt?
hey im tyring to change the timing belt on a 97 lx...i want to know how do i adjust the outer belt before the timing belt. its the smaller belt inside the t blet cover before the timin belt...thanks in advance
Old 01-21-2009, 08:35 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: 97 Accord Lx timing belt?
see my write-up that is linked in the faq
Old 01-21-2009, 09:05 AM
mouab18c1's Avatar
thanks! but what was your title for it? i tried a few search words but no luck
Old 01-21-2009, 01:07 PM
nguyener's Avatar
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-timing-belt-timing-balancer-belt-water-pump-f22b1-1908944/
Old 01-22-2009, 06:55 AM
mouab18c1's Avatar
thanks appreciate it alot
Old 01-22-2009, 08:27 AM
H-T Order of Merit
and for future reference, it's the first link in the Engine section of the Accord FAQ that is stickied at the top of the Accord forum
Old 01-22-2009, 08:42 AM
mouab18c1's Avatar
alright i was confused so i just clicked on the Faq headline and got no where..but thanks alot
Old 01-22-2009, 09:56 AM
H-T Order of Merit
ah, I never realized that was there wasn't before the switch to vB. I'll be sure to be more specific next time
Old 01-06-2010, 05:16 PM
New User
Tampab0y's Avatar
Hello everyone, Im new to this forum, I just had my mechanic change the timing belt on my 97 accord EX wagon 176,000 miles and now the car runs rough @ high rpms, is not even shifting right, it doesnt feel the same, could it be they tighten the belt too much?? I have no clue what is going on, any help will be greatly appreciated.
thanks.
Old 01-06-2010, 07:56 PM
nus_dogg's Avatar
If the belt is too tight, you'll have a whurring noise.
Old 01-07-2010, 06:59 AM
New User
Tampab0y's Avatar
THanks Nus....there is no noise, it just runs rough.....they moved the distributor a little bit and it got a little better, but still runs rough, specially when Im in the highway....I read it could be the balance belt is either too tight or not installed correctly....could this be it?
Old 01-07-2010, 05:09 PM
djkurious's Avatar
Or did the mechanic not line up the timing marks.......TDC is your friend!
Old 01-07-2010, 07:48 PM
nus_dogg's Avatar
I don't think its your balancer belt at all because I've tighten those balancer belt soo tight that they created that whurring noise(very loud at idle). I didn't feel any roughness. Just naturally let the tensioner do the tension, do not push or add any pressure to get the balancer belt tight.
Have you done any tune up lately? spark plugs, wires, and cap?
Old 01-13-2010, 01:50 PM
New User
Tampab0y's Avatar
Hello everyone and thank you for the replies, I took the car back to my mechanic, they took everything apart again, checked belts, tension and according to them everything has been installed correctly, they loosened the timing belt just a little and put everything back together, now the car is running fine.....they probably didn't install it right the first time, but of course they are not going admit to it.....
thank you all again.
gnx547
07-24-2010 12:01 AM
NewfieAccordEXR
09-03-2006 01:06 PM
1998hondaaccord
08-12-2004 12:59 PM
david90
06-19-2004 12:39 PM
Quick Reply: 97 Accord Lx timing belt?
