97 Accord Head bolts TORQUE specs?
Old 04-24-2008, 09:25 PM
Pinche Caro's Avatar
Default 97 Accord Head bolts TORQUE specs?
I need head torque specs for a 97 accord 4cyl. f22b. and also the for the rocker arms. I tried searching and couldnt find anything.
Old 04-25-2008, 04:52 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: 97 Accord Head bolts TORQUE specs? (Pinche Caro)
when standing in front of the car looking at the engine, the torque sequence is as follows.
Head bolts...
8---6---2---4---10
9---3---1---5---7
you torque them in three steps
1 - 29lbs-ft
2 - 51lbs-ft
3 - 72lbs-ft
as for the rocker arm assembly bolts, the torque sequence is different between the F22B1 and F22B2 but the torque specs are the same...
8mm bolts = 16lbs-ft
6mm bolts = 9lbs-ft
Old 04-25-2008, 02:37 PM
Default Re: 97 Accord Head bolts TORQUE specs? (TouringAccord)
Thanks! U the man
Old 04-25-2008, 06:17 PM
oem_certified_accord's Avatar
rocker arm bolts are 10mm and 12mm's TA
Old 04-26-2008, 07:59 AM
H-T Order of Merit
Default Re: 97 Accord Head bolts TORQUE specs? (oem_certified_accord)
yes and no. I was referring to the thread size and you would be referring to the head size... if I'm not mistaken.
Old 04-26-2008, 10:05 AM
lol what?
head bolts = 14mm, rocker arm assembly bolts = 10mm backside, 12mm frontside & midrow.
unless your mean the vtec monster head, then that would make me feel dumb
Old 04-26-2008, 10:58 AM
i think he means the size of the thread of the bolt.
Old 04-26-2008, 01:25 PM
ahhhh thread PITCH and size. gotcha
edit: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">yes and no. I was referring to the thread size and you would be referring to the head size... if I'm not mistaken.</TD></TR></TABLE>
right over my head, didn't see you said thread size lol.
Old 09-03-2011, 07:48 AM
lethalaccord's Avatar
what happen if you break one of the rocker arm bolt, the 10 mm backside bolt? please someone chime in.
Old 09-03-2011, 09:16 AM
Lost Again's Avatar
You'll need a new one, and get the old one out.
Old 09-03-2011, 10:37 AM
dang, i was afraid of that. how long do you think i can go with this problem? i will need some time to save up money and get a new head. rather than a new head, i might just get me a new motor cause this engine has 340,000 miles.
Old 09-03-2011, 11:06 AM
Lost Again's Avatar
Depends on you budget???
Me, I'd pull the rocker assy and see about getting the old one out.
Old 09-03-2011, 11:14 AM
i was thinking about that but the 10mm bolt is too small. what do you think can get that broken bolt out?
Old 09-03-2011, 04:10 PM
got it fixed. took it apart and used a magnet and twist that broken bolt out. now gotta do my valves again bc its ticking pretty loud. ahha
Old 09-04-2011, 04:58 PM
newhondagirl's Avatar
what was your main goal here??? to replace the head gasket??? did you use a new clean head? i also had a broken bolt on the rocker a few days ago...bout died for a min...lol but it was cake to get out just used some needlenose pliers. i had it off to replace the o rings on the bottom but....my main problem is i have a BHG and will be doing a head job on my car in the next couple weeks. i would love any help on this as i will be doing it myself and i have never done anything like this before...
Old 09-05-2011, 05:35 AM
Im new to the accord scene so the goal was just to replace the o rings on the bottom of the rocker arms, which i never knew cause i've always had an civic or s2000.
check the FAQ thread. there should be something on how to remove BHG.
Old 01-07-2013, 05:55 PM
jmuldo's Avatar
What about the engine cover? What is the torque specification? I need to do my valve cover gaskets, I am leaking oil into my spark plugs.
Old 01-08-2013, 03:58 AM
H-T Order of Merit
7.2 lbs-ft
Old 01-08-2013, 04:50 PM
jmuldo's Avatar
Sweet I appreciate it man, is there a specific order I would have to tight the bolts?
Old 01-09-2013, 04:15 AM
H-T Order of Merit
no problem
uh, it's been a while and I don't have my manual handy... but iirc start in the middle and work outward alternating sides as you go.
Old 01-25-2019, 02:16 PM
sisithaw's Avatar
Could you please tell me if this torque sequence is valid for Honda F18B engine as well? Or Can you share the the same?
henry_manalo
04-24-2018 09:38 AM
anothersickhatch
12
06-10-2004 02:26 PM
NOOTRON20
10-11-2003 10:18 AM
Hybrid
10-11-2002 10:44 AM
Quick Reply: 97 Accord Head bolts TORQUE specs?
