96 Accord, leaking coolant from backside of engine. - Honda-Tech
Old 05-16-2010, 11:53 AM   #1
SlammedDC2teg's Avatar
Default 96 Accord, leaking coolant from backside of engine.
I have a 96 Accord that is leaking like crazy from the backside of the motor, right by the water pump where the pipe that connects to the thermostat.
Has any one had a similar problem? I don't want to spend to much time, nor money fixing this car. It was hand me down with over 200k. I can do the work my self, but I just wanted to see if any one has had the exact problem, and what is it?
Also does any one have a PDF of repair manual for a 96 Accord.
Thanks in advance HT.
SlammedDC2teg is offline   Reply With Quote
Old 05-16-2010, 12:40 PM   #2
cctgene's Avatar
Default Re: 96 Accord, leaking coolant from backside of engine.
cctgene is offline   Reply With Quote
Old 05-16-2010, 02:50 PM   #3
sony224422's Avatar
there are o rings. I had the same problem.. if the pipe isn't lined up right then you nick the o ring and it leaks eventually. I also had mine rust out and it had a pin hole leak. Bought a new one, 2 new o rings, and was good as new. Its not too hard to do either, just make sure you take the bolt out of the bracket that holds it, and lube the o rings before shoving them in.
sony224422 is offline   Reply With Quote
Old 05-16-2010, 04:40 PM   #4
^+1 Right on man. I'm going to pick some o-rings up and do the job. Thanks
Old 05-16-2010, 07:11 PM   #5
the thermostat housing can be a b$tch to get out, but yea....definatly that O-ring. Its an easy fix. Shouldn't take more than about 45mins to do yourself. Drain your coolant out from the plug on the bottom of the radiator before you do it or you will have a mess on your hands. Might as well change your thermostat while you are there too since I think you gotta take out the thermo housing anyway to get that pipe off. and maybe the radiator hose that connects to the housing if its looking old.
quickster is offline   Reply With Quote
Old 05-16-2010, 09:59 PM   #6
Quote:
What would I use to lube them?
Old 05-17-2010, 12:02 AM   #7
RICKSAUTOMOTIVE's Avatar
Quote:
WD-40...tri-flow....something like that. i spray my finger and lube the O-rings by wiping them. just put enough to help you get it together
RICKSAUTOMOTIVE is offline   Reply With Quote
Old 05-17-2010, 01:34 PM   #8
sony224422's Avatar
yep anything is better than dry lol.. spit if you have to.
Old 05-17-2010, 01:35 PM   #9
sony224422's Avatar
Quote:
when i did mine, you don't have to take the thermo out.. i took off the whole assembly as one. I think there is a gasket behind there too actually just so you know.
Old 05-17-2010, 03:18 PM   #10
Thanks for all the help fellas. I just finished. The back bolt that holds the pipe was a PITA to take out and put back. It probably would have taken me 20min to do the job rather than 2hrs, due to the bolt. Other than that is was a $6 fix. Thanks again for your help.
Old 05-17-2010, 04:33 PM   #11
sony224422's Avatar
no problem.. atleast you knew about the bolt lol.. first time i did it i had no idea and i couldn't figure it out until i saw it. i found a 12 mm gear wrench to be my best friend after that.
Old 05-17-2010, 04:51 PM   #12
That's exactly what I wished I had.
Old 06-09-2014, 10:22 AM   #13
Icon2 Re: 96 Accord, leaking coolant from backside of engine.
I have the same problem with my 97 Honda accord. I am not a professional mechanic, but I try to do what I can. I saw that you guys said it only takes about an hour to fix, but I thought I had to lower or higher the engine to do it. What do I need to take out first to get to this area?
Mashchanic is offline   Reply With Quote
Old 06-17-2014, 09:12 AM   #14
I have a 96 Accord with vtec 4 cyl. there is a leak that will actually trickle coolant if you remove the radiator cap so the system can breath. even with a mirror I can't see the spot, but it is under/near the intake port for the cylinder nearest the thermostat.
looking at the diagram, it appears that there is a distribution pipe under there with several hoses.
there is also a bleeder bolt down there somewhere!
seems my best bet is to remove the intake piping and try for a clearer view. does anyone have any other suggestions?
maknes is offline   Reply With Quote
Old 06-17-2014, 09:33 AM   #15
to: Slammeddc2teg,
check the weep holes on the side near the water pump. if the pump seals have failed then coolant will come out one or both these holes. It's normal when this happens for there to be flow for a minute or two after shutting off the engine while it depressurizes.
only solution is water pump replacement.
it is driven by the timing belt so it makes sense to replace that too while you're in there, and also the counterbalancer belt that is behind the lower part of the timing belt.
not very expensive, but involved and time-consuming.
Old 02-14-2015, 08:47 PM   #16
Quote:
Originally Posted by maknes View Post
to: Slammeddc2teg,
Dang, I'm surprised someone bumped this thread. But it was the water pump. Sold the car about 2 years ago. Had 250k
oil leaks from back of the block raverx3m Tech / Misc 6 03-14-2015 11:12 PM
Water Leak in Honda accord 2002 Sedan SE with moonroof rraju Introduce Yourself 1 03-09-2015 02:11 AM
95 Accord 2.2 Oil Leak market525 Honda Accord (1990 - 2002) 3 10-05-2010 05:16 AM
Transmission leak.. repair or buy a new one? whattodo Acura Integra 5 05-31-2007 06:56 PM
coolant leak from back of the block.. somewhere.. help hb_guy Tech / Misc 4 02-24-2006 02:45 PM
Tags
90, 91, accord, backside, bottom, coolant, engine, honda, hose, leaking, pin, pipe, radiator, tech, thermostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
