95 accord tie rod replacement question???? - Honda-Tech
Old 02-28-2011, 11:00 PM   #1
dtran002's Avatar
Default 95 accord tie rod replacement question????
Hey guys, I just want to know how hard it is to replace the inner tie rod on the 95 accord? I looked around and my question is that do I need a special tool to unbolt the inner tie rod? I look on those auto parts websites and the picture of the inner tie rod end nut look normal and remove by using a regular wrench. I haven't go out and see the actual yet, so I just wondering if I can even just do it at home without special tool or let the shop do it.
Thanks
dtran002 is offline   Reply With Quote
Old 03-01-2011, 05:23 AM   #2
TOP END MS's Avatar
Default Re: 95 accord tie rod replacement question????
If your working on your Accord I recommend you utilize the Honda Service Manual. It is available for download on HondaSwap(dot)com.
TOP END MS is offline   Reply With Quote
Old 03-01-2011, 10:29 AM   #3
dtran002's Avatar
I downloaded the manual, and the manual does not cover how to change the tie rod, mostly on camber and caster works. I searched around and they all mention need a special tool, but thats for 97+, just wondering if the older model are the same.
btw, how do I check if I need to replace the inner tie rod? I was told to have them both replace when I did my alignment at Pepboys. I know for sure I need the outer one, but not so much on the inner.
Old 03-01-2011, 11:43 AM   #4
InvaderTrax's Avatar
Jack the front up, move the tire side to side, and see if the inner tie rod is clunking around
InvaderTrax is offline   Reply With Quote
Old 03-01-2011, 01:48 PM   #5
Accordin2me's Avatar
Pepboys told you the tierods are bad and they still aligned it? And you got an alignment with a known bad outer? Not wise my friend.
Accordin2me is offline   Reply With Quote
Old 03-02-2011, 12:23 AM   #6
dtran002's Avatar
Well, they did it and then tell me that I should get it replace. I guess I still need an alignment while waiting to change the tie rod since I changed my control arms and somehow this time my tires are worn out faster than normal
Replacing the Inner Tie Rod - 08 CR-V bob78cvcc Honda Element & CR-V 8 12-10-2012 02:46 PM
how to remove inner tie rod on a 94 accord jetblack3s Honda Accord (1990 - 2002) 17 01-08-2012 05:49 PM
inner tie rods SQ is the SQUAD Suspension & Brakes 3 05-30-2011 10:27 PM
tie rod replacement, help? dfJDM Honda Civic / Del Sol (1992 - 2000) 25 12-26-2010 05:28 AM
EF inner/outer tie rod help B16Blake Honda CRX / EF Civic (1988 - 1991) 2 03-30-2010 05:52 PM
Tags
1995, 2005, 95, accord, change, discount, honda, price, replace, replacement, rod, sale, setting, socket, tie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
