95 Accord Rim/Tire size question
I have a 95 Honda Accord LX which came with stock 185/70/14. The EX models came with 195/60/15 and V6 with 205/60/15.
The question is: can I install 205/60/15 with 98-02 Accord 15" rims on my 95 Accord without compromizing the speedometer accuracy? Meaning is the 205/60/15 will be the same height as my stock 185/70/14? Im just trying to go a bit wider on the tire and up on the rim for my future brake upgrade.
And I dont want to go with 16" 17" or 22" with spinners as some people might suggest in the reply, lmao. Im trying to keep a stock look.
Re: 95 Accord Rim/Tire size question (HONCORD)
The 205s would be a bit bigger and throw th speedometer off.
the 195/60/15 and the 185/70/14 are pretty much the same
I just made that switch today
Re: 95 Accord Rim/Tire size question (02 accord)
Now can anyone expain how in the fk 205/60/15 are different in height compared to 195/60/15. I understand the 205mm V.S. 195mm but if they both are 60mm height sitting on the 15" rim. How can 205 influence the height?
search on google for "miata tire calculator" and u can see the difference in tires and dimensions. it will even tell you how much your speedo will be off.
for example:
normally on accords 94-97 with 17" wheels they suggest you run 215/40/17 or 215/45/17. i actually run 235/40/17!! i am a wheel and tire salesman btw. the only way i got this info was thru using the tire calculator.
g/l
for example:
g/l
