95' Accord EX Lifter noise
Im having a bit of lifter noise, not alot or anything to take away power, but its still there. I was just wondering if there was any way to get it to stop? Well... without changing lifters or anything. Any input would be really appreciated.
Re: 95' Accord EX Lifter noise (BlueLude84)
lifters are used in push rod motors, not over head cam motors. you are most likely due for a valve adjustment or have noisey injectors
Re: 95' Accord EX Lifter noise (YeuEmMaiMai)
THERES ACTUALLY A SERVICE BULLETIN ON THIS.. IT DOES HAVE TO DO WITH THE VALVE ADJUSTMENT.. HERE IT IS.. I GOT LAZY SO IM JUST GONNA COPY AND PASTE..
98-009
April 13,1999
Applies To:
1995-97 Accord-All Ohio-built LX and DX models
Ticking Noise From the Valve Train
(Supersedes 98-009, dated June 23, 1998)
SYMPTOM
Ticking noise from the valve train.
PROBABLE CAUSE
Intake rocker arm shaft clearance is excessive at the number two cylinder.
CORRECTIVE ACTION
Adjust the valve clearances, or replace the cam holder and the adjoining intake rocker arm shafts at the number two cylinder.
PARTS INFORMATION
Cam Holder kit/N 12010-P0B-305, H/C 5686423
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies.
Failed part: P/N 12100-P0B-A00
H/C 4288247
Defect code: 042
Contention code: B07
Skill level: Repair Technician
Out of warranty: Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Service Manager or your Zone Office. You must request consideration, and get a decision, before starting work.
REPAIR PROCEDURE
1. Let the engine cool, then remove the valve cover.
2. Measure the intake valve clearance at the number two cylinder intake valve closest to cylinder number one.
^ If clearance is more than 0.40 mm, replace the cam holder. Refer to section 6 of the S/M.
^ If clearance is less than 0.40 mm, go to step 3.
3. Adjust the valve clearance. If no adjustment screw threads are visible above the locknut, replace the cam holder. Refer to section 6 of the S/M.
98-009
April 13,1999
Applies To:
SYMPTOM
PROBABLE CAUSE
CORRECTIVE ACTION
PARTS INFORMATION
H/C 4288247
Defect code: 042
REPAIR PROCEDURE
Re: 95' Accord EX Lifter noise (loup05)
Now would this service be covered free for me, since it was a defect per say? Or should i just call my usual service shop and get my valvles adjusted?
-Edit- I also noticed that u said it was for DX and LX models, well mine is an EX, will that affect it?
madcrossover
04-18-2005 03:55 PM
