'95 accord 2.0i tdc sensor error 8 - Honda-Tech
Old 11-30-2004, 09:18 AM   #1
Slaine's Avatar
Default '95 accord 2.0i tdc sensor error 8
Hi. New user but read most of related posts across all forums.
Recently car not starting first time, turning over 4 or 5 times (cold here in uk if that is a factor) CEL comes on and car starts. CEL stays on. I then would turn off and restart until car started with out the CEL remaing on permanently. I have noticed that car after 10 minutes or so of running would then just stall with CEL remaining on. Can restart immediately and continue. Also today car resisted acceleration for a second and CEL light came on again but didn't stall. Are all these problems related? After viewing this web site, I ran the paperclip diagnostics test! got error code 8 only.
If TDC sensor is my problem can someone help with the following?
Is the TDC Sensor inside the distributor cap?
Do I have to replace distributor?
If I do do I have to have the timing redone?
Can I line up new distributor as before?
Do I need a new sensor or 2nd hand one, same for distributor?
Any assistance would be great, I'm a novice as you can tell, my Haynes manual is on order but 3 weeks wait!
Many thanks
Slaine is offline   Reply With Quote
Loss of (engine)power. Jimmyb0000 Honda Civic (2001 - 2005) 7 05-13-2015 10:10 PM
Acura 1.7EL (Honda Civic) D17A2 - very weird intermitent problem and no CEL da-fox Honda Civic (2001 - 2005) 4 03-29-2015 04:44 PM
Jdm eg6 civic intermittent problem,HELP! Eg6.Civic Honda Civic / Del Sol (1992 - 2000) 3 02-26-2009 06:30 AM
1988 Civic, 1.5l - Check Engine Light @ 60-70 MPH - error code 4. austincivic Honda CRX / EF Civic (1988 - 1991) 4 01-29-2007 10:10 PM
Gurus Needed! Several problems: Intermittent CEL, No cruise, and how do you adjust ignition timing? Xerxes25 Honda Prelude 7 06-25-2004 01:55 PM
Tags
1995, 94, 95, 95honda, accord, acura, code, cold, err8, error, honda, located, replace, sensor, td, tdc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
