Car won't start...getting frustrated
Old 01-11-2009, 09:46 AM
faithypoo's Avatar
Default Car won't start...getting frustrated
Background. I have a 93 accord and it died on me a few weeks ago. I thought it was because oil flooded the spark plugs and in which I removed all plugs and cleaned out the oil. Still no fire. I thought I diagnosed the problem by replacing the main relay considering that there was no spark to the coils. Still no fire. I don't know if it is the timing belt, the distributor or what. When I crank the car, I can hear the relay that I just replaced click but I don't get it to turn over. I just don't know what it is. I really don't know what to do now except to bring it to a mechanic, but I can't afford to do that right now. If I can get some help to diagnose what is wrong with it, then it would be helpful. This is urgent. Thank you.
Old 01-11-2009, 10:41 AM
TOAB's Avatar
Default Re: Car won't start...getting frustrated
Errr... so you do, or do not have spark at the moment?
Old 01-11-2009, 11:40 AM
jrzy2nR's Avatar
need spark and fuel.... do the dumb friend test with the spark plugs to see if they spark. also did make sure your getting fuel
Old 01-11-2009, 11:43 AM
faithypoo's Avatar
No, I'm not getting any spark and how do I test whether or not I'm getting fuel?
Old 01-11-2009, 12:49 PM
Stashu915's Avatar
the main relay does not usually cause no spark. 95% of the time the fix for your problem will be an ignitor. the ignitor is located inside the distributor and is pretty easy to replace.
Old 01-11-2009, 01:07 PM
jrzy2nR's Avatar
ok well problem one no spark....
to check for fuel do you hear the fuel pump prime when you turn the key to the on position?
it may be your ignition and coil use the search button there are many threads about people with problem starting their car
hey man
01-10-2011 02:28 PM
crexsi
05-08-2009 06:44 PM
slvrcvc93
04-28-2007 06:52 PM
valerie34
06-30-2005 07:42 AM
Quick Reply: Car won't start...getting frustrated
