94 accord wont start...
ok so i was driving when all of a sudden my car just shut off. i tried pop starting it while i was still moving and nothing.
ive changed ignition coil, distributor, main relay, ive also checked the timing over and over. pretty sure grounds are good.
this is the first time this has happened to me, it seems like if the timing is dead on it will just crank and crank but no spark.
if the timing is off it tries to turn over.
im so lost... :\
im so lost... :\
Re: 94 accord wont start...
check all fuses and check for proper power supply to all components. also test the ignition control module. you'll need a manual for most of that.
ok im getting spark now all of a sudden but its still not trying to start. could it be because i have a f22a6 cam and cam gear on it? when i first put the cam and cam gear on it ran fine for about a week then it just died.
REDBARON
26
04-01-2017 08:20 PM
