ABS modulator bleed procedure?
Old 04-09-2024, 01:16 PM
LSLOCKHEED1's Avatar
Default ABS modulator bleed procedure?
1994 honda accord DX (with antilock brake system)
What is the proper way to bleed the modulator? There is a bleed valve/screw on the top of the module itself. I am replacing every line in the vehicle and air will get into the module so I need to know proper bleed procedure. I noticed if I remove the signal wire (but keep ground connected) on the brake fluid reservoir level sensor, the abs pump cycles with KOEO
Old 04-12-2024, 03:52 PM
LukeM's Avatar
Default Re: ABS modulator bleed procedure?
Is this what you're looking for?
Old 04-12-2024, 05:41 PM
Yes ineed, thankyou so much for the reply! I am running all new brake lines and thought while I am at it might as well run the master cyl to modulator lines but I know I am gonna get air into the modulator, thanks so much!
davidluko
04-27-2008 06:36 PM
The-Kid
12-26-2006 04:12 PM
guymosiris
01-10-2006 04:58 PM
MikeTV
08-05-2003 02:23 PM
4doorH22
10-07-2001 06:12 PM
Quick Reply: ABS modulator bleed procedure?
