94 Accord Ex starting problem...distributor not the problem - Honda-Tech
Old 07-25-2005, 12:46 PM   #1
1,000,000to1's Avatar
Default 94 Accord Ex starting problem...distributor not the problem
94 Accord Ex has a starting problem. Sometimes it will start and sometimes it won't. Replaced the distributor. Still having same issue. Also replaced the fuel filter. Any ideas? Thanks in advance!
1,000,000to1 is offline   Reply With Quote
Old 07-25-2005, 12:54 PM   #2
Default Re: 94 Accord Ex starting problem...distributor not the problem (1,000,000to1)
Why didn't you check the starter first? Go have it tested to see if it is going out or not. Sometimes when they are going out they will intermittently work and then not work.
SpeedFreak77 is offline   Reply With Quote
Old 07-25-2005, 01:01 PM   #3
Took it to the shop and they said it was the distributor. Paid for it to be replaced. Then it broke down again and had the fuel filter replaced. They never mentioned the starter. I thought it either worked or it didn't. Is this a common mistake for a automotive shop? Could it be something else? Thank you.
Old 07-25-2005, 09:06 PM   #4
deserthonda's Avatar
i am assuming car is cranking and not starting correct???? if it cranks it has nothing to do with starter ........ a lot of shops especially non honda specialist will not detect the problem correctly but i think any shops would not replace the distr or fuel filetr if you had a starter issue man i hope they are not that bad ,,, for this reason i am assuming car cranks but wont start .....
you could have a cracked soder in main relay
deserthonda is offline   Reply With Quote
Old 07-26-2005, 03:19 AM   #5
Hello,
Yes, the car will crank. It just doesn't always start up. Can you please tell me a little more about having a cracked soder? Where would it be? Is it an easy fix? Is it pricey to have done? Thank you so much for your help. Can't wait to have my car back to normal.
Old 07-26-2005, 07:19 AM   #6
the main relay is located under the dash on a 94 i believe it is on the right side of steering column, it has 7 wires going to it and it is kind of brown/rusty color ...remove relay. pry open the 2 little tabs get a magnified glass sometimes the crack are small and harder to see anyho, chk the soderings if you see any cracks resoder and reinstall most of the time there are only 2 that are cracked ..
but when car does not start you want to make sure that it is fuel or spark related first ..if it is lack of fuel the relay is a good place to start i have seen a **** load of them go bad
Old 07-26-2005, 03:31 PM   #7
Banned
94accordsedan's Avatar
Starter would be my guess. Mine had similar starting issues that were fixed after replacing the starter. 5th gens didn't have too many issues with the main relay unlike 4ths.
94accordsedan is offline   Reply With Quote
Old 07-26-2005, 04:24 PM   #8
Default Re: (94accordsedan)
i agree with you not as many but i have already done 3 this summer all on 94 accords
Old 07-27-2005, 10:45 AM   #9
JimBlake's Avatar
Default Re: (deserthonda)
Quote:
If this is true, I don't see how the starter could be the problem.
JimBlake is offline   Reply With Quote
Old 07-27-2005, 06:29 PM   #10
Thanks so much for all the help! Glad we narrowed it down between the starter and the main relay. Just a quick poll to anyone who cares to give me an additional 2 cents. The car went in the shop 2 weeks ago. Took 7 days to get it back. Paid for a used distributor, which they were nice enough to install, instead of the $300 model. Total only ended up costing me $160. Car broke down same day and went back. They replaced the fuel filter, just in case that was the problem(at no expense to me). Which it wasn't. It's been a week and they just seem to busy to make it right. Plus they just don't have a clue as to what is wrong. So, my question is... What is the company responsible for? And what would you expect the outcome to be on this situation? I don't want something for free. Just a fixed car and not having got screwed over financially in the process.
Old 07-27-2005, 11:01 PM   #11
well if they replaced dizzy 1 time and fuel filter next time sounds like they dont have a clue they are playing the guess and hope fixes it with customer money ....
they should know wether it is sparkor fuel related and again ,,,IF CAR CRANKS ( TURNS OVER BUT WONT START ) IT IS NOT THE STARTER ,,,,,,,let me say it again if car cranks it is not the starter contrary to what some other people have stated ,when it does not start remove tube from throttle body and spray carb cleaner in there if it starts it is fuel related ......or hook up a fuel pressure gauge and chk fuel pressure ............when it does not start pull a plug wire off stick a screwdriver in wire end and ground it, crank car if no spark could be ignitor, rotor, cap, coil ...it is real easy to know wether it is fuel or spark problem
94 Accord EX - Distributor replaced and now getting CEL code 9 jerry5150 Honda Accord (1990 - 2002) 6 05-11-2015 08:21 AM
Intermittance Starts - 94 Accord nickmcpher Honda Accord (1990 - 2002) 5 03-28-2015 10:26 AM
94 civic random shut off while driving, B swapped LSVTEC96HB Tech / Misc 11 02-05-2014 05:46 AM
1997 honda accord ex f22 start problem jdmcertified909 Honda Accord (1990 - 2002) 13 04-04-2012 03:03 PM
93 Honda Accord Wont Start moo32moo32 Honda Accord (1990 - 2002) 4 05-16-2011 02:36 PM
Tags
94, accord, distributor, honda, intermittent, problems, relay, srarting, starting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
