NEED HELLP, H22A swap into 99 accord
whats going on fellas , anyways i need help i just wanted to know if someone may let me know everything i need to pull an h22a swap in a '99 5spd honda accord , your help will be much appreciated thanks
Re: NEED HELLP, H22A swap into 99 accord
Going to have a hard time getting someone to spoon feed you information when you bump your thread 5 times in 20 minutes. you have to be a bit more patient than that if you want help.
Honestly I have no idea what parts you need. I'm just here to let you know that it may take longer than 16 minutes for someone to help point you to the information that is readily available using the search tools available on this site and the internet.
your going to need the motor obviously lol see if ur tranny will mount to the h22 tranny some motor mounts that will be able hold the engine rewire your harness and the ecu... i think you may have to get a new downpipe... not sure maybe it will fit your oem one. i did a h22 swap into my 96 accord but converted it from auto to manual.. so there was a bit more work there to be done but seeing that you have all the necesseties already aside from the motor you shouldnt run into to many expenses.. might be a nice project seen a few 98 99 accords with h22's
you right ma
no problem oh yeah i forgot you will need axles and maybe the axle shaft for a prelude other than that thats it i think
mightymikek83
06-15-2005 01:59 PM
