Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda Accord: how to bleed air out of your power steering pump
Step by step instructions for do-it-yourself repairs.
94 accord ex power steering fluid bleeding
Just replaced the alternator and power steering pump on my 94 EX
alternator working great, power steering fluid just keeps foaming and overflowing the bottle on the side of the fender well.
How the hell do I bleed this system to get the air out????!!!!
I've picked up a bottle of the Honda specific fluid...
I've started the car and let it sit for the bubbles to go out several times to no avail...
Help please!
Thanks
Dan
Help please!
Thanks
Dan
Re: (Ross 2.0)
no loose lines, only removed the two lines where the bolt to the pump. O rings are intact, fully tightened etc...
poor design/parts location, the bottle isn't at the top of the system so it doesn't bleed easily
In a Junkyard near you.
If you're sure it's not sucking air. Start the car and turn the steering wheel back and fourth lock to lock several times and it should purge the air.
If not you might have a bad pump or a kinked line.
Re: (Ross 2.0)
I did that too... I'm ythinking that the pump is bad. I got it because the old one squeeked sometimes on starting the car, it stopped if I sprayed lube into the bearing behind the pulley.
This one squeels all the time... very noisy pump... I guess that a boneyard pump wasn't a great idea...
those things are a pain in the ***. i usually just top it off start the car and shut off after a few seconds. go refill and start again, do this until the fluid is leveld off for the most part then just turn wheel lock to lock.
FMohlmann
11-18-2016 12:28 PM
radeonboy
10-12-2007 07:14 AM
