97 Accord RPM jumps but car doesnt move.
Alright I have an issue with the Accord again. The car will drive fine when its cold but after long drives and warm weather the RPM would rev up as if the clutch was slipping. I swapped out for a new clutch and the stupid thing still did the same thing. So this past weekend I replaced the flywheel since the clutch was pretty much brand new. It still does the same shyt but it does not occur as much anymore. What can it be? Clutch pedal holds pressure good, shifts like butter but like I said the RPM gauge will rev up like the clutch is slipping but it makes no sense, since both the flywheel and clutch/ pressure plate are brand new. Any ideas? Any info would be great, if it was my car it would have been sold already LOL
Re: 97 Accord RPM jumps but car doesnt move.
you need to post more info. does it do this from a stop? or on the highway? will it do it if you ease on the throttle?
how often do you sit at a light with the clutch pressed in?
either way, assuming theres no grease on the PP flywheel etc, sounds like the throw out bearing isnt being released properly, did you replace that with the new PP? if its not that then the slave cylinder that moved the clutch fork is probably worn. hows the clutch fluid?
Misadjusted clutch pedal? How much free play do you have? Also, bleed the clutch line. This sounds exactly like the symptoms I had. Everything was fine when cold, but once warmed up, all my free play went away (air in the line expanded).
Free play is how much the clutch pedal moves down before you start feeling the pressure from the pressure plate (that was redundant, wasn't it? Lol). If that free play decreases once warmed up, it's most likely air in the line.
Smcneal1970
06-11-2018 06:54 AM
darrinirox
10-28-2011 08:48 PM
