94 accord CV axle removal? - Honda-Tech
Old 01-14-2010, 10:24 AM   #1
Greatness's Avatar
Default 94 accord CV axle removal?
So I took the lower ball joints and everything Im trying to pull out the CV axle right now. Problem is its not budging and it looks like the rubber boot is stretching. Is there a proper technique to pull them out?
Greatness is offline   Reply With Quote
Old 01-14-2010, 12:27 PM   #2
accord99power's Avatar
Default Re: 94 accord CV axle removal?
if outer joint is disconnected from the rotor hub aseembly then the inner joint that goes into the transmission needs to be pryed out between the joint and tranny.
accord99power is offline   Reply With Quote
Old 01-15-2010, 10:42 AM   #3
Greatness's Avatar
Im trying to remove the inner joint on the half shaft from the intermediate shaft or support shaft. Even with a pry bar its still not coming out.
CV Axle possibly? gotgohan Honda Civic / Del Sol (1992 - 2000) 3 09-22-2013 09:33 AM
Cv Axle And Cv Axle Seal SlvrJdm Honda Civic / Del Sol (1992 - 2000) 9 10-28-2012 07:24 PM
Ar the bearings the same on prelude cv joint and integre cv joint Gary B Transmission & Drivetrain 0 08-07-2010 10:26 PM
cv axles williamkeen Transmission & Drivetrain 1 02-08-2010 08:57 PM
Axle & CV joint out of place... B18CivicEH2 Tech / Misc 5 03-19-2007 06:13 PM
Tags
1996, 2007, 94, accord, axle, boot, cv, half, honda, intermediate, joint, management, project, removal, replacement, shaft, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
