93' idle flux after braking??
ok- so I have been doing all the research on the idle problems on these cars. I have cleaned my IACV and made sure my FITV is tight. After I cleaned the IACV it seemed to have gone away and it idled lower (about 650 which I thought was correct). Its back! After the car is warm, I have noticed that hitting the brake pedal will surge the idle up and then it starts to fluctuate some. Then if I let it sit with my foot off the brake it sometimes calms down (sometimes it just keeps surging). I think the ECM detects brake pedal and boosts idle, but why is it boosting it so much-- is a sensor bad or ECM bad? Any other suggestions??
oh- and the rpms it flux's between is 1500 and 1100. If it settles it has been going to 900 but now it never seems to go down to 650.
Re: 93' idle flux after braking??
The brakes are vacume assit from the engine. A classic symtom of a vacume leak is idle change or flux? I would see if the vacume hose going to the brake booster/master cylinder is cracked or leaking or worse the booster diaphram inside the brake booster is leaking vacume while under load..
B16A CRX
05-06-2009 04:17 PM
stripes777
04-27-2008 02:34 PM
RACEPAK
11-23-2006 01:33 PM
