93 honda accord front end problems - Honda-Tech
Old 12-30-2010, 02:53 PM   #1
Default 93 honda accord front end problems
I took my 93 Accord in because it has been making noises, and there are a variety of problems with the front end.
First, the mechanic told me the rotors are slightly warped, and since the hub bearings are original he said he'd have to replace both the hubs and rotors (hub is all rusted up). I have noticed some vibrating when breaking sometimes, but it doesn't seem to be too bad, and it doesn't always happen.
The front spring on the driver's side has snapped. He said I should replace the entire strut on both sides.
He showed me that there was some play in the control arm, and has both front upper control arms with ball joints as well as the sway bar link/kit and outer tie rod end in the quote.
The total cost of all this comes to be more than what the car is worth. The car seems to be running pretty good, so I was wondering what things I could do (maybe myself) to just keep the car safe. Is it unsafe to drive with the broken spring? Could I just replace the single broken spring rather than both struts? Could I replace the bushings in the control arm rather than the whole arm and ball joint? Can I get away with just leaving the rotors? The brake pads look fine.
I just want this car to be safe on the road for the next year or two, so things like irregular wear on the tires are not really a concern to me. I just need this thing running while I save up for a new car. How hard would it be to do some of this work myself? I don't have much experience but have a friend that does who can help me.
Thank you for the assistance.
rubbersoul is offline   Reply With Quote
Old 12-30-2010, 06:54 PM   #2
Default Re: 93 honda accord front end problems
I'd at least replace the whole strut assy with a used one. Don't even bother looking for another spring just find another whole used assy.
Replace all the ball joints should be $45 for just the lowers
Sway bar endlinks are about $10 a side.
Tie rod ends should not be any more than $50 plus an alignment so figure another $60.
Nicefeet is offline   Reply With Quote
Squeaky front end markb Honda Accord (1990 - 2002) 10 03-16-2014 02:10 AM
How to confirm that sqeaking is coming from sway bar bushing? Rob_KCMO Honda Accord (1990 - 2002) 5 10-13-2010 05:48 AM
front control arm question on a 2000 civic? killaj12 Honda Civic / Del Sol (1992 - 2000) 2 01-28-2007 09:03 PM
4th gen prelude suspension tune-up help Ludefun Suspension & Brakes 2 12-12-2005 01:21 PM
94 Accord EX suspension problem. disastar Honda Accord (1990 - 2002) 5 08-04-2004 08:04 PM
Tags
1991, 1993, 2002, 93, accord, arm, balljoint, broken, control, end, front, honda, problems, replace, replacing, spring, struts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
