93 fan kicks on and stays on long after car is shutoff?? - Honda-Tech
Old 04-23-2007, 03:53 AM   #1
jgcox6's Avatar
Default 93 fan kicks on and stays on long after car is shutoff??
How long should the fan run after the car is shut off? My 93 runs for like 10 to 15 min after it is shut off...I also have the dreaded low idle when the car is in gear..idles fine in park..but drops to 500rpm when it is in gear. I have checked/cleaned the IAC, FITV, and the air boost. One procedure said it was the air boost when finished with the test...ever heard of one of those going bad?
jgcox6 is offline   Reply With Quote
Old 04-23-2007, 09:52 AM   #2
Bruce Banner's Avatar
Default Re: 93 fan kicks on and stays on long after car is shutoff?? (jgcox6)
10-15 is longer than it should.
This could be a cooling issue.
Are you driving it hard?
Bruce Banner is offline   Reply With Quote
Old 04-23-2007, 10:30 AM   #3
JimBlake's Avatar
First, rule out an overheating problem. If this is caused by TRUE overheating, then you can replace your thermostat or check for a plugged radiator, or something along those lines.
Does this happen even when you drive a short time - so the engine's not even warmed up?
Look where the UPPER radiator hose is attached to the head. There's a sensor there (a fan swich) - unplug it while the fan is running after shutoff. If that makes the fan stop, then get a new switch.
Background:
There's 2 fan switches on your car. The one in the thermostat housing (lower radiator hose) is responsible for switching the fan while the ignition is turned on. The one at the upper radiator hose is responsible for switching after shutoff. There's a fan timer module to decide which switch controls, and to shut off the fan even if the switch is stuck closed.
Not all years of Accords have this same system, so everyone else who finds this thread has to be careful which years...
JimBlake is offline   Reply With Quote
Old 04-24-2007, 08:38 AM   #4
jgcox6's Avatar
Default Re: 93 fan kicks on and stays on long after car is shutoff?? (JimBlake)
You asked "Does this happen even when you drive a short time - so the engine's not even warmed up?" I was just idle in the driveway...actually trying to figure out a low idle problem when it goes in drive. The fan would kick on even after I shut it off...and would run for sometime. The car was at operating temp. I am going to do the little test you suggest about pulling the connector off.. I really appreciate you time and expertise.. Have you ever had a Air Boost Valve go bad? That is what started all of this..
A/C fan keeps going after shutting off engine on '97 Accord Roniszoro Tech / Misc 1 08-27-2014 11:06 PM
A/C Fans Keep running after shutting down car Roniszoro Honda Accord (1990 - 2002) 0 08-26-2014 03:27 AM
93 Accord Fan stays on after shutting off. 93Accordman Tech / Misc 5 03-21-2014 06:25 AM
Cooling Fan Runs Randomlt 92 Accord zrsm9 Honda Accord (1990 - 2002) 4 08-13-2010 09:13 AM
93 accord, overheating at idle/stop. New water pump, no leaks, fan works... Tim 95 M3 Honda Accord (1990 - 2002) 8 05-24-2009 01:16 PM
Tags
91, accord, acura, acuras, car, engine, fan, honda, long, overheating, pilot, runs, shut, shutoff, stay, stays
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
