'93 Accord Oil Change
Old 05-02-2002, 12:17 PM
briq4's Avatar
Default '93 Accord Oil Change
OK I've changed my oil hundreds of times, and on the air filter box it says 3.7 quarts with filter. So I put in 4 whole quarts and it never is at the second hole in the dipstick, anyone else notice they have to put in more than it says? OR is my car odd? Also I was down in Florida and took my car to a dealer down there to get the oil changed, and they changed it so I checked it and it was about a half an inch OVER the second dot, when I went to the guy he said that's where it's supposed to be, they measure it exactly etc etc etc. So with these things in mind, who's right? Do I go by the dipstick? Or do I go by the quantity (i.e. just do 4 quarts and that's that?)
Old 05-02-2002, 12:19 PM
SOHCArchangel's Avatar
Default Re: '93 Accord Oil Change (briq4)
is it on a level surface oO?
Old 05-02-2002, 12:20 PM
briq4's Avatar
Default Re: '93 Accord Oil Change (SOHCArchangel)
yup.
Old 05-02-2002, 01:08 PM
New User
HondaCivicEx98's Avatar
Did u change ur dipstick?
Old 05-02-2002, 01:10 PM
briq4's Avatar
Default Re: '93 Accord Oil Change (HondaCivicEx98)
Nope that's what came with the car, although it had 36K on it when I got it but how do you loose a dipstick?
I guess my real question is how much do you guys put in when you change ur oil?
Old 05-02-2002, 01:39 PM
Chiovnidca's Avatar
I won't speak for anyone else, but I put in 4 quarts and don't worry about it.
Old 05-02-2002, 01:40 PM
92accord4life's Avatar
i usually put in 3 q's, drive it for about 5 minutes and then check and fill with about another quart. so, in short 4 q's.
Old 05-02-2002, 03:14 PM
Banned
CardDealer's Avatar
Default Re: '93 Accord Oil Change (92accord4life)
I use 4 quarts, run it for a minute and then check. I believe 3.7 quarts is the volume not including the oil filter.
Old 05-02-2002, 07:52 PM
smokin rubber's Avatar
Default Re: '93 Accord Oil Change (schlit)
I always use a little more than 4.
Old 05-03-2002, 05:15 AM
4doorH22's Avatar
Maybe you should stop looking at air filter boxes and look in the manual? I'm pretty sure the manual says ~4 quarts with filter.
Old 05-03-2002, 05:38 AM
89_LXi's Avatar
Default Re: '93 Accord Oil Change (4doorH22)
I always put in an even 4 quarts. It puts it just a tiny bit above the 2nd dot, but I'm not gonna worry about that small amount. Never had a prob
Old 05-03-2002, 09:17 AM
Razor's Avatar
on my 94 ex(f22b1 vtec) i put in 4.25 quarts with a small can(not sure about how many onces) of BG MOA(engine oil treatment). my oil is exactly at the top dot on the dip stick. i usually put the 4-4.25 quarts of 5w-30 in and run the car for like 2 min to fill the oil filter with oil, then shut if off and check the dipstick and then i add more as needed. just remember that you turn on your car for the first time after putting in new oil so the oil filter can be filled up.
that is all.
Old 05-03-2002, 11:54 AM
kcxtremeaccord's Avatar
I work at Jiffy Lube so let me halp all Honda peeps
non-VTECH = 3.75 - 4.00
VTECH = 4.00 - 4.25
those are the recomendations from Honda themselves.
Old 05-03-2002, 01:50 PM
New User
Gennady's Avatar
3000 X 100 = 300,000
Damn, thats a lot of miles.
[Modified by Wont be beat, 5:51 PM 5/3/2002]
Old 05-03-2002, 02:27 PM
briq4's Avatar
Default Re: '93 Accord Oil Change (Wont be beat)
OK OK so it was 74 times. only at 222,000.
[Modified by briq4, 6:27 PM 5/3/2002]
Old 05-03-2002, 04:15 PM
Default Re: '93 Accord Oil Change (ILiveNextToSabastian)
VTECH = 4.00 - 4.25
well that dont work for me, my non vtec f22a1 needs more than 4qts
Old 05-03-2002, 04:18 PM
4doorH22's Avatar
Default Re: '93 Accord Oil Change (smokin rubber)
My non-VTEC F22A6 took 4.0 quarts every 3,000 miles for 135,000 miles. Never burned a teaspoon of oil 10 years.
Shizzle my nizzle.
Old 05-04-2002, 08:29 AM
nickg11111's Avatar
i work at jiffy lube also. the reason you all have different levels is that different oil filters have different capacities. for example, the mileguard and fram filters (3593A) hold a little more than a quarter quart. the capacity honda gives you is for the oil pan capacity, not including the filter. fill the engine w/ oil, start the car, then the oil will fill the filter. depending on the capacity of the oil filter, it will take a certain amount more oil than recommended.
Old 05-04-2002, 09:44 AM
Default Re: '93 Accord Oil Change (nickg11111)
NOw that we have changed to penzoil filters they changed everything in the computers so that it dows include the oil filter
the filter for HOnda is now PZ33
[Modified by ILiveNextToSabastian, 6:44 PM 5/4/2002]
Old 05-04-2002, 10:00 AM
New User
Big James's Avatar
I just fill it until it pours out the top. I figure if I can do this with my radiator, why not my oil. Besides, you can never have too much lubrication.
On a side note, I would go by the dipstick.
[Modified by Big James, 2:01 PM 5/4/2002]
Old 05-04-2002, 12:30 PM
Razor's Avatar
Default Re: '93 Accord Oil Change (Big James)
are you serious?
Old 05-05-2002, 05:09 PM
New User
Gennady's Avatar
I heard too much oil ***** up the catalytic converter.
Old 05-05-2002, 08:33 PM
Razor's Avatar
and can soak up the spark plugs
Old 05-05-2002, 10:19 PM
briq4's Avatar
Default Re: '93 Accord Oil Change (Razor)
I heard too much is no good either. Well I did check the manual finally and it says 3.7 w/o filter and 4 with. Odd that the sticker on the air filter box didn't have it as 4 given Honda recommends changing the filter with every oil change, however, I think that 7,500 miles is way too long between changes.
So do you guys change the filter every oil change? I do and I use the Honda filters. Too much?
Old 05-06-2002, 05:28 AM
New User
Gennady's Avatar
Unless its K&N or something that is speficially for re-use, it should be changed with every oil change as far as I know.
Quick Reply: '93 Accord Oil Change
