93 ACCORD Fuel Pump Location - Honda-Tech
Old 08-02-2008, 06:58 AM   #1
Default 93 ACCORD Fuel Pump Location
93 Honda Accord 4 Door Lx
I need to change Fuel Pump and have checked the Hayes Manual and it states that it is in gas tank. And that I need to remove the gas tank.
I have had people tell me that there is an access panel underneath the back seat. Is there anyone that knows if this is true?
moo32moo32 is offline   Reply With Quote
Old 08-02-2008, 09:00 AM   #2
Mr Yamada's Avatar
Default Re: 93 ACCORD Fuel Pump Location (moo32moo32)
The way to find out if you have to drop the tank, is to look for a round access panel behind the rear seat in the trunk floor.
I believe the fuel level sending unit is on the pssenger side and IF there is an access panel on the drivers side it will be for the fuel pump.
Mr Yamada is offline   Reply With Quote
Old 08-02-2008, 09:21 AM   #3
MenaceAccord92's Avatar
You must drop the tank to change the fuel pump. There is an access panel, but not big enough to remove the fuel pump. To do that, you must cut/enlarge that hole.
MenaceAccord92 is offline   Reply With Quote
Old 08-02-2008, 10:06 AM   #4
Default Re: 93 ACCORD Fuel Pump Location (MenaceAccord92)
Any idea what the access panel is for if the pump wont fit through it?
Old 08-02-2008, 08:50 PM   #5
JDM_DC4_Fanatic's Avatar
its so you can unplug the fuel pump and see if its getting power if it ever needs to be serviced.
JDM_DC4_Fanatic is offline   Reply With Quote
Old 08-11-2008, 01:38 PM   #6
Default Re: 93 ACCORD Fuel Pump Location (JDM_DC4_Fanatic)
Thanks to all for your comments. I believe I have a Main relay problem, hopefully it is not fuel pump.
93 Honda Accord Wont Start moo32moo32 Honda Accord (1990 - 2002) 4 05-16-2011 02:36 PM
WTB DA FRONT WHEEL HUBS Mr_Moos Northwest (Sales) 0 05-29-2010 11:51 AM
Need Tophat ASAP Mr_Moos Northwest (Sales) 1 02-21-2009 09:51 PM
Car Randomly Dies? any ideas Mr_Moos Honda CRX / EF Civic (1988 - 1991) 5 05-05-2007 11:58 PM
Weird "moo-ing" noise towards back underneath of car after turning it off... Lang Acura Integra Type-R 16 07-22-2002 01:58 PM
Tags
1990, 93, access, accord, back, find, fuel, honda, located, location, panel, pump, removal, remove, replacement, seat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
