93 Accord with camber kit and upper control arm problems.
Old 05-04-2005, 09:22 AM
rillboss's Avatar
Default 93 Accord with camber kit and upper control arm problems.
I have a 93 Accord. I have installed an adjustable camber kit on the upper control arms and I have Tein Super Street suspension with Suspension Techniques sway bars.
My problem is the upper control arm smashing into the top of my wheel well.
I grinded the edge off of the control arm and it helped a little but it still hits hard on certain bumps. I was going to cut out the section of the wheel well but don't know if it will cause problems or work.
Any help with this isssue would be appriciated!
If you don't know or you are a stock only person please do not waste my time by responding.
Thanks!
Rill Boss
Old 05-04-2005, 11:07 AM
zeroice's Avatar
Default Re: 93 Accord with camber kit and upper control arm problems. (rillboss)
i have the same problem... I have a totally different setup and i have had 5 different accords and lowered them all, but this 92 accord i have now seems to do the same thing yours is doing, i too grinded down the control with little help, sorry i cant help but i cant seem to figure it out either...
Old 05-04-2005, 11:30 AM
rillboss's Avatar
Default Re: 93 Accord with camber kit and upper control arm problems. (zeroice)
My Accord is really a 92 not a 93.
I'm going to cut out the spot in the wheel well where it is hitting.
Old 05-05-2005, 07:31 AM
SearchBeforeUPost!'s Avatar
There is not alot you can do to solve your problem. When the CB chasis is lowered too far and corrected with a camber kit, the UCA's will hit the chasis over hard bumps. I have seen a guy cut out that strut tower area, but doing so weakens the frame and structural rigidity of the car. Another option is to "push" that area out a little (some people use a scissor jack to do this), freeing up some travel space for the UCA.
Old 05-05-2005, 09:48 AM
rillboss's Avatar
Default Re: 93 Accord with camber kit and upper control arm problems. (SearchBeforeUPost!)
Thanks! I will try to push the area out and see if it works before I cut.
Old 05-08-2005, 04:55 PM
MADMAXX's Avatar
I have a '93 Ex I have a tokico setup coilovers adjustable shocks got SPC camber kit. When I had it lowered over some bumps it hit but I wasn't sure what it was. I'm going to have check when i lower it again but before I had 7spoke 5th gens now I have 17" so we'll see.
GreedyAzn
04-22-2007 09:02 PM
JimnVa
08-16-2006 02:55 PM
rillboss
05-16-2005 11:04 PM
92LudeSI
06-05-2004 07:45 AM
OzzieAccord
10-18-2001 07:47 PM
Quick Reply: 93 Accord with camber kit and upper control arm problems.
