93 Accord Cabin leak
Old 09-11-2016, 03:09 PM
Awestenbeeragg's Avatar
Default 93 Accord Cabin leak
I've got a 93 Accord EX and ever since I bought it 2 years ago it's had a really bad cabin leak that me and my dad just got around to chasing down. It dumps on the passenger floor only. We took out all the carpet and put an air compressor hose in the sunroof drain and on the drivers side and could hear it blowing out by the drivers side tire. This drain seemed fine and clear of debris, so we put it on passenger side and blew it out, nothing. No air coming out near the tire like it was on the drivers side. I could hear air coming out from inside the cabin so we took off the kicker panel and sure enough we could see the hose that looked like it was sheared off at an angle near the blower motor, and feel the air blowing out. So I was wondering if the hose that goes from the sunroof drain to the tire had a connector that it could have slipped out of because the way the hose is right now it looks way to clean of a cut to have been broken or ripped apart. Thanks in advanced!
Old 09-11-2016, 05:17 PM
holmesnmanny's Avatar
Default Re: 93 Accord Cabin leak
thats the evaporator drain for the ac, it drains down to the ground from the evaporator thats behind the glove box, completely normal, hook it back up
it might be clogged so you can shoot the hose that goes to the ground with some compressed air to check if its clogged
Old 09-11-2016, 05:22 PM
No I think the AC drain hose was under the car but this one was from the sunroof as we ran wire from it, we did also clean out the AC drain as well and water poured out haha. But we did confirm the hose came unplugged from the elbow but seems too short to plug back in so it must've shrunken some how. Guess we're pulling the headliner out to replace that hose
Old 09-11-2016, 05:25 PM
Ohhh unless you're saying the evap hose connects to the sunroof drain hose as well. It looked like there was some sort of connector/splitter in there but we tried to get at it without pulling the dash out so it was pretty tough to see
thequesogrande
06-26-2013 09:56 PM
carl1864
12-03-2010 03:19 PM
96AccordMD
06-16-2009 10:38 AM
Schlag96
07-06-2007 01:18 PM
dave f
07-23-2006 04:32 AM
Quick Reply: 93 Accord Cabin leak
