92' EX overheating issue.
Old 11-29-2013, 03:28 PM
foxyride22's Avatar
Default 92' EX overheating issue.
My 92 ex is overheating and I'm not to sure why. At idle it will be fine but once I start to drive it overheats and when I turn the heater on it blows nothing but cold air. What's could be causing this?
Old 11-29-2013, 04:47 PM
tim73's Avatar
Default Re: 92' EX overheating issue.
Have you checked your water level? Sounds like it may have some air
Old 11-29-2013, 04:50 PM
foxyride22's Avatar
Fluid level is fine bled the system the other day.
Old 11-29-2013, 09:37 PM
tim73's Avatar
Has the radiator been flushed recently? I would try that, also replace the tstat with OEM honda. If that doesnt work, I would think water pump is weak. However, the symptoms do indicate a air bubble.
Also, when cold, remove radiator cap, start engine, check to see if it shoots out coolant
Old 11-30-2013, 09:16 PM
MM Gruppe B
MAD_MIKE's Avatar
Did you have any recent work done?
If the system was opened make sure the heater is turned to full hot while bleeding the system. I ususally just leave the bleeder screw open while refilling to aid in a faster fill/bleed.
Old 12-02-2013, 05:47 PM
dirty-rob's Avatar
if level is fine in the radiator and no air pockets are present ,make sure the heater valve is open and the cable is attached to the **** so itll turn from hot to cold... if it was blowing hot a few days ago and you havent moved the **** from hot to cold and all of a sudden it isnt blowing hot id suspect a clogged heater core or faulty themostat
Old 12-02-2013, 06:37 PM
foxyride22's Avatar
haha I feel like a goof but I bled it one more time to see if I did get all the air out and turns out I didn't. re-bled the system and now she works fine. thanks for all the advice I really appreciate it.
Bill Leland
06-12-2014 02:29 PM
VRD^don
12-07-2011 08:44 PM
darkblackH2B
12-15-2008 07:08 PM
briq4
Honda Civic (2001 - 2005)
10
02-05-2007 10:43 PM
return_2020
12
02-12-2005 05:51 AM
Quick Reply: 92' EX overheating issue.
