'92 AT Accord, vibration only in reverse, this has got me stumped. - Honda-Tech
Old 03-20-2007, 12:50 PM   #1
secondgen's Avatar
Default '92 AT Accord, vibration only in reverse, this has got me stumped.
I've got a buddy with a '92 Accord, automatic, and there's a very noticable vibration, only when the car's in reverse and warmed up, when it's cold and at a high idle, the vibration's gone.
So far, I've gone through and checked the following, all motor mounts, all sensors, resistance readings are within specs. replaced the rear motor mount as it wouldn't hold a vacuum. cleaned the throttle body, checked for vacuum leaks, checked to see if the EGR was stuck, or dirty. Reset ECU numerous times (no codes). Also messed with the idle, giving it a high idle will help, but it's gotta be above 1k. So really, so far, nothing has helped.
Any ideas would be greatly appreciated.
secondgen is offline   Reply With Quote
Old 03-20-2007, 04:23 PM   #2
hondadude's Avatar
Default Re: '92 AT Accord, vibration only in reverse, this has got me stumped. (secondgen)
Go to the front subframe 'dogbone' motor mount. The top bolt allows adjustment.
Try starting the car and leave it in park, then loosen and retighten that top bolt.
If that doesn't make it shift it's position, try putting it in drive and have someone hold the brake and repeat loosening and tightening.
It's way better to have the vibration in reverse than to have it in drive. LOL
hondadude is offline   Reply With Quote
Old 03-20-2007, 05:13 PM   #3
1990AccordBoy's Avatar
Default Re: '92 AT Accord, vibration only in reverse, this has got me stumped. (hondadude)
I have a 90' accord AT with that same problemoo , i dont think its a problem tho , basically when i turn on my car it goes to about 1500 RPM then it like auto accel's to likee 1700-1800 RPM and stays there for a while then slowly climbs down to 1500 RPM.. then when i put it in R the RPM drops ( which makes it hum..( think logically here ) and then obviously im off.. and then theres that sweet NEEAARRR noise when i back up thats the sweetest part of the car in my opionon lol!
Edit: The car does this when its cold and high idle.. not so much whe nits warmed up because the accord is desigend 2 have a high idle during warm up so it goes up n down by itself to warm the engine faster, most people dont relize that and they put their RPM's down so it'll take longer to warm up, anyways, when my car is hot like a quarter warm, it still vibrates a bit but not as much because the RPM's drop whne you put it in R.. if u havent noticed.
1990AccordBoy is offline   Reply With Quote
91 Hatch Vibrations Pt 2 - Need a mechanic! McMahon Honda CRX / EF Civic (1988 - 1991) 0 11-10-2013 07:44 AM
Short Clutch Release and Vibrations Constantly! HELP! Ls1Powerz Transmission & Drivetrain 2 08-09-2013 11:01 AM
Vibration in steering wheel at idle??? Mattl12 Honda Accord (1990 - 2002) 2 08-27-2011 09:05 AM
Rough Idle/Vibration with/without A/C on DaChoZn1 Honda Accord (1990 - 2002) 17 01-06-2011 09:45 AM
1991 Accord vibration at idle fever502 Honda Accord (1990 - 2002) 6 01-09-2006 06:49 PM
Tags
1700, 1990, accord, backing, honda, idling, motor, mounts, noise, only, reverse, rpm, vibrates, vibrating, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
