What's this code really mean?
1993 Accord, start the car, runs for three minutes NO ABS lights, move the car about 30 seconds later ABS light comes on. These are the codes:
1-4 The Pressure Switch
8-1 Operation of the ABS
So what does it mean, I guess the pressure switch is, well the pressure switch, but what about 8-1 Operation of the ABS?
Thanks
Zeek
Thanks
Zeek
Re: What's this code really mean?
8-1 can be triggered if you drive down a rough road or hit a few potholes. It's triggered when a wheel sensor signal disappears at speeds below 10 kph (6 mph)
Both 1-4 & 8-1 codes can point to a faulty ABS control unit.
Clear/Reset your ECU/DTC codes and try this for the 8-1 code.
